Knock sensor on 1.8T
Edinburgh, Scotland
Hey guys for a while now on vag.com my car has brought up a knock sensor code saying signal to high or something similar.
This has been the case for the past 3 years so I dont think and hope it can not be anything serious.
I have ordered a green plugged sensor but I also notice there is a blue plugged one as well. Does anyone have any experience with similar faults and have any info?
I maybe should have ordered both sensors and just replaced them both?
i'd imagine with a knock sensor fault the ecu will ****** the timing a bit to keep everything safe...
Yeah I do sometimes drive along at a steady 70 for a long time and if I put the foot down the car does not respond as well. Is like the car is then just a n/a 1.8 or something.
Would this be the case because of a sensor fault?
I dont ever get a check engine light.
Hi mate,
you getting the following error?
Address 01: Engine Labels: 058-907-55x-AEB1.lbl
Part No: 8D0 907 557
Component: 1,8l R4/5VT MOTR HS D05
Coding: 04001
Shop #: WSC 00000
3 Faults Found:
16716 - Knock Sensor 2 (G66): Signal too Low
P0332 - 35-10 - - - Intermittent
00561 - Mixture Adaptation
14-10 - Adaptation Limit (Add) Exceeded - Intermittent
17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded
P1327 - 35-10 - - - Intermittent
i replaced both of mines theres a Green sensor and a blue sensor cost £70 for both from eurocarparts. PITA to fit as there under the intake mani and the connectors are under the coolant tank!
