Rear Right Brake Light Bulb Gone - Easy To Change?
emzino
Surrey
Hi all. Just yesterday I got a DIS Warning about my Rear Right Brake Light Bulb gone and it needs to be changed. I checked and it does.
Now is it an easy job to do it yourself or would I be better of getting someone else to do it? Also what kind of bulb does it require?
Many thanks!
remove the circular cap inside the boot, then use a flat headed screwdriver to remove the plastic bolt and then pry the light off from the tailgate side to the side of the car. there are two ball pin thingys holding it on. the bulb can then be replaced. do the opposite to replace the glass.
Thank you =) Will have a go at it later
