far too low imo, only veedubs can get away with scraping their sumps! raise it 10mm and you will be spot on. you will probably also eat through some driveshafts having it that low!
i use mine as a daily driver and i have never hit the sump i just have to take speed bumps slow, and i have had my rear tires on for about 20 thousand miles and the sides are still fine....
Then you can't drive it like I drove mine.
Mine was at least 25mm higher and I had scuffs on the sump from back roads...even with Bilstein dampers on...and the inside edges wear on the rear tyres even with the standard quattro GmBH suspension on, never mind any lower.
This unfortunately, is a fact.
People should do as they wish...
But rip your sump off or wear your tyres out on the insides...and don't come back here crying about it.
