S3 Dave said:The oil used on a non paper item reduces the life of your MAF also!!
james0808 said:Why is it that almost everytime someone asks a question about air filters there is someone who bangs on about the oil damaging the maf,where is the proof?and i dont mean he/she says it does so it must be true.
Sam-K said:BMC i have heard good things from..
..Don't worry about all this "max power special" talk.. Are race cars "max power specials" ?.. .. they must be as they use cone filters..on rally and gt applications.
Ess_Three said:When was the last time you saw an open filter on a race car, Sam?
Sam-K said:Donnington 2006, Morgan aero v8.
it was a red bmc cone, right behind the front grill. Good source of cold air if you ask me.
and that is when i last saw an open filter on a race car.
Ess_Three said:And follow on to explain how an open filter right behind the grill and hence in the airflow, on a race car normally doing 100 MPH +, makes an open cone filter on an A3/S3, sitting right beside the firewall, next to a red hot turbo, sucking in air at 50 degrees + on a car that sits in traffic, is just as good an idea.
This I'd like to hear...
Touring cars, GT cars (most...except Morgan it seems), F1, WRC all use fully ducted inlet tracts to get cold dense air and some form of ram air effect.
Even squashed beetles have cold air ducting for the GT3 cone filters (BMC) on the 'Cup' cars...despite having the engine at the wrong end.
Dave_Bayern said:Good point
Like a K&N, it sits slap bang in the middle of the engine bay, not next to the firewall, but I see your point, its right in the middle of all the heat.
And given that the S3 doesnt have an empty wheel wheel to be able to accommodate a CAI then standard filter with a decent feed seems the best idea by far.
Co-incidentally I'm back to using a standard airbox with a 4" feed and its WAY better than the Carbonio I had on there, not noticable in terms of power, but noise is greatly reduced and mid range appears to be a little stronger.
glen_jai said:I've just had a pipercross panel filter fitted with my turbo conversion.
I had the MAF replaced at the same time because it was mis-reading according to backdraft.
The panel filter is the dry type (no oil). Let you know how I get on.
If the Maf goes now then the finger pointing could be conclusively directed at the air filter.
james0808 said:What filter was on your car before the pipercross?
If the panel filter is dry,no oil,how can the finger be pointed conclusively at the air filter.
The only MAF i had to replace was on a totally standard A4 using the paper filter.What caused that to break???Draw your own conclusions....
james0808 said:What filter did you have?
Is there any noise difference with the pipercross?
Sounds like you have had some nice mods done to the S3,should make for a very nice car.glen_jai said:I just had the standard Audi paper filter before.
I can't really tell if there's a noise difference because there's been so much other work done on the car at time of changing the filter such as new downpipes, sports cat, turbo, forge dv etc.
I wouldn't have thought there's much noise difference to the standard paper filter, as it uses the same airbox. If you want some noise, you'll have to go down the CDA route.
I prefer a quieter car... though it's pretty darn loud now, slightly embarrassing.
If i remember right the pipercross are made from layers of sponge so dont need any oil.S3 Rav said:what are the differences apart from the obvious between oiled and non oiled. why would you have one and not the other or is it just the way they're made?
james0808 said:If i remember right the pipercross are made from layers of sponge so dont need any oil.
