HappyCamperz
As stated in title, I bought a 2013 Audi A3 8v PFL 1.6tdi recently, it was sold as a "cat N, with a Facelift front end and airbag light on and needs DRLS coding" its the right colour (ie black) is S-line looks good and was lowish mileage and money so took the plunge.
Aswell as an airbag light on, I also get "front indicator" warnings and "headlight range" error on the dash. In additon air con is blowing just outside air, fuel cap doesnt lock. I assumed it would come with sat nav & parking sensors but it doesnt, I will sort these out at some point but main concern is current fault codes. I bought VCDS and just did my first scan - see below.
main things I want to know is,
- did they wire the front lights in properly by looks of it and what do I need to do to clear those codes?
- air bag light - can I just clear that code and be ok or do the codes show something more needs doing?
- air con faults do they show anything sinister or will a regas sort it?
- any other causes for concern?
I got a key locking fuel cap for now and car drives really nice tbf although no info on cambelt change as history was rubbish that came with car
any help/info gratefully receieved, I'm a novice to VCDS etc so please go easy
Friday,24,May,2024,19:37:36:49714
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WAUZZZ8V8EA029603 License Plate: SV63 AKG
Mileage: 129436km-80427mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V8EA029603 Mileage: 129436km-80427miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 AL HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5516
Revision: 84H22--- CVN: 71E3EF91
Coding: 02190012030501092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906021AL 002009
ROD: EV_ECM16TDI01104L997021.rod
VCID: 6FBBC40107112F52BE9-803A
VINID: 9D196AAAA2262154400891800CF8F42571
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 617930000003D3
Coding: 12F18AA224220A75017D060041C62548512450806082A4F2004100040508
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 7BA3E051436943F2021-802E
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 HW: 8V0 820 043
Component: AC Automat H13 0031
Revision: 20023000 Serial number: 00000000112201
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
ROD: EV_AirCondiFrontVaAU37X_008.rod
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 8F9886B6000000000001
2 Faults Found:
262914 - Refrigerant Pressure
B10AB F0 [00001001] - Too Low
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 42
Mileage: 128613 km
Date: 2023.10.07
Time: 13:55:02
Outside temperature: 18.5 °C
Engine RPM: 922.50 /min
Compressor current: actual value: 0.000 A
Temperature downstream of evaporator: 21.9 °C
Refrigerant pressure: 1.0 bar
System run time-Engine running time: 0 s
System run time-Terminal 15 on: 253 s
329476 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [00001000] - Actuator Stuck
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 86
Mileage: 128650 km
Date: 2023.10.25
Time: 00:00:36
Voltage terminal 30: 14.5 V
Inside temperature: 8.6 °C
Outside temperature: 8.5 °C
Fresh air/recirculating air/back pressure door specified value: 873
Actual value for fresh air/recirculation air flow flap: 512
Actual value for fresh air/recirculation air flow flap: 83.5 %
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011318400412 Dataset Number: 8V0909514C 0063
Coding: 07000A424241205D03844004B31C07A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_011.rod
VCID: 77ABFC617F416792669-8022
Wiper motor control module:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130612 041 0580
Serial number: 130614163852
Coding: 0A47F7
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Component: E1 - LDS MQB H05 0032
Serial number: 24 04 2013 00000503
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY131560L55
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000056947272
11 Faults Found:
5130 - Bulb for Front Left Turn Signal
B11E8 15 [00001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 42
Mileage: 128636 km
Date: 2023.10.17
Time: 12:57:08
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 14.6 V
Outside temperature: 9.5 °C
5386 - Bulb for Front Right Turn Signal
B11EA 15 [00001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 50
Reset counter: 43
Mileage: 128636 km
Date: 2023.10.17
Time: 13:09:38
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.8 V
Outside temperature: 10.5 °C
6666 - Bulb for Low Beam Headlamp Left
B1217 15 [00001000] - Open or Short to Plus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 73
Mileage: 128778 km
Date: 2024.02.16
Time: 17:11:47
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: operated
last_wakeup: gültiges Funktelegramm
Voltage: 12.1 V
8714 - Bulb for Left Fog Lamp
B121F 15 [00001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 128703 km
Date: 2023.12.17
Time: 19:24:40
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 14.7 V
Outside temperature: 10.0 °C
8970 - Bulb for Right Fog Lamp
B1220 15 [00001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 128703 km
Date: 2023.12.17
Time: 19:24:40
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 14.7 V
18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [00001001] - Voltage Supply Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 128636 km
Date: 2023.10.17
Time: 05:46:14
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.0 V
Outside temperature: 4.5 °C
19210 - Right LED Module for DRL and Parking Lights
B12ED F2 [00001001] - Voltage Supply Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 128636 km
Date: 2023.10.17
Time: 05:46:14
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.0 V
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [00001001] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 41
Mileage: 128636 km
Date: 2023.10.17
Time: 05:53:12
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.9 V
Outside temperature: 5.0 °C
197904 - Central Locking
B140A 4B [00001000] - Over Temperature
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 76
Mileage: 128877 km
Date: 2024.05.11
Time: 12:35:59
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.0 V
Outside temperature: 22.0 °C
204546 - Remote key 2
B147A 18 [00001000] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 128636 km
Date: 2023.10.17
Time: 13:10:21
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.9 V
267030 - Siren / Alarm Horn for Anti-Theft Alarm System
U1137 00 [00001000] - Implausible Message
[Sirene-DWA->unplausible Botschaft]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 74
Mileage: 128814 km
Date: 2024.03.07
Time: 19:57:37
CAN-Bus_aktiv: OFF
OFF: Not operated
Low beam: operated
Voltage: 12.3 V
Outside temperature: 6.0 °C
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R027RKO Dataset Number: 8V0909602C 0007
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4BC3709153493372F21-801E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 002 806 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000DA779EC0E
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 002 806 13
Component: SideSensor_Pf 001 0887
Serial number: 35867000000F5779EC0C
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 401 506 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502B3106FA245294
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 401 506 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502B1106FA24B356
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 402 706 13
Component: FrontSensor_D 001 6149
Serial number: 355650299106FA23B39I
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: -----------
Component: PedP_Sensor_D --- ----
Serial number: -------------------$
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: -----------
Component: PedP_Sensor_P --- ----
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: -----------
Component: PedP_Sensor_C --- ----
Coding: 2D2D2D
5 Faults Found:
9451547 - Igniter 1 for pedestrian protection
B1038 1B [10001001] - Resistance Too High
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:50
9451803 - Igniter 2 for pedestrian protection
B1039 1B [10001001] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:50
9450005 - Pedestrian Protection Crash Sensor (driver's side)
B1032 15 [10001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:53
9450261 - Pedestrian Protection Crash Sensor (passenger's side)
B1033 15 [10001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:53
9496853 - Front Crash Sensor for Pedestrian Protection
B10E9 15 [10001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:53
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 01071308490328 Dataset Number: ----------
Coding: 8418
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_009.rod
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 970 N HW: 8V0 920 970 N
Component: KOMBI H03 2211
Coding: 27840A002A8046000100A800000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 47CB4CA14F21D712D69-8012
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000706812 Dataset Number: 8V0909515C 0044
Coding: 030100040B0876005B000248080B00000001000000000000000000000000
GVL: 01503C0000000000400C10000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: 3B23205103E983F2421-806E
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 01 07 2013 C0293801
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051656164
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 17061302090356 Dataset Number: 8V0909872D 0025
Coding: 00108E204001040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 3FDB544117F19FD26E9-806A
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Dataset Number: 8V0909852F 0015
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D272E491DFD8DC27C5-8068
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 16061302090435 Dataset Number: 8V0909873D 0024
Coding: 001086204001040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 3E25294510FB96DA65F-806A
3 Faults Found:
65578 - Motors for Central Locking
B122B 12 [00001000] - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 86
Mileage: 129352 km
Date: 2024.05.15
Time: 07:06:10
65579 - Motors for Central Locking
B122B 11 [00001000] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 91
Mileage: 128613 km
Date: 2023.10.07
Time: 13:56:55
65593 - Switch for Central Locking
B122D 29 [00001000] - Signal Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 86
Mileage: 129351 km
Date: 2024.05.15
Time: 07:03:52
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: -------------- Dataset Number: 8V0909865D 0028
Coding: 018C000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: 75B7F669654D1582745-8020
3 Faults Found:
5275220 - Headlight
C107E 54 [10001001] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 14
Mileage: 128636 km
Date: 2023.10.17
Time: 05:44:34
5276949 - Positioning Motor for Headlight Range Left
C1085 15 [10001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 34
Mileage: 128636 km
Date: 2023.10.17
Time: 05:44:37
5277205 - Positioning Motor for Headlight Range Right
C1086 15 [10001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 34
Mileage: 128636 km
Date: 2023.10.17
Time: 05:44:37
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 874 A HW: 8V0 035 874
Component: MU-S-ND-ER 040 0370
Serial number: A7F00507131485 Dataset Number: 8V1909545A 0028
Coding: 01730300FF00000021111101000A00002F0001460100010002
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3A2D25550CD3BAFA597-806E
Multimedia System 1:
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H48 0013
Serial number: AUZ8Z9DG601X90
Multimedia system control head:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000008051300020619
1 Fault Found:
6179 - Display Module 1 for Multimedia System
B1297 F6 [00001000] - Cable for Video Signal; Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 69
Mileage: 128786 km
Date: 2024.02.17
Time: 17:45:43
Voltage terminal 30: 12.1 V
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 21061301100365 Dataset Number: 8V0909897B 0012
Coding: 000086204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXKLO.rod
VCID: 41DF52B96105E92218D-8014
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 010 0006
Serial number: 21061303110516 Dataset Number: 8V0909896B 0012
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.3V)-----------
www.Ross-Tech.com
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 42
Mileage: 128613 km
Date: 2023.10.07
Time: 13:55:02
Freeze Frame:
Fault Priority: 2
Reset counter: 86
Mileage: 128650 km
Date: 2023.10.25
Time: 00:00:36
Coding: 0A47F7
Light switch:
Alarm horn:
11 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 42
Mileage: 128636 km
Date: 2023.10.17
Time: 12:57:08
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.6 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 50
Reset counter: 43
Mileage: 128636 km
Date: 2023.10.17
Time: 13:09:38
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.8 V
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 73
Mileage: 128778 km
Date: 2024.02.16
Time: 17:11:47
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 12.1 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 128703 km
Date: 2023.12.17
Time: 19:24:40
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 14.7 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 128703 km
Date: 2023.12.17
Time: 19:24:40
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 14.7 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 128636 km
Date: 2023.10.17
Time: 05:46:14
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.0 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 128636 km
Date: 2023.10.17
Time: 05:46:14
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.0 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 41
Mileage: 128636 km
Date: 2023.10.17
Time: 05:53:12
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.9 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 76
Mileage: 128877 km
Date: 2024.05.11
Time: 12:35:59
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.0 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 128636 km
Date: 2023.10.17
Time: 13:10:21
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.9 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 74
Mileage: 128814 km
Date: 2024.03.07
Time: 19:57:37
CAN-Bus_aktiv: OFF
OFF: Not operated
Low beam: operated
Voltage: 12.3 V
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:50
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:50
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 128613 km
Date: 2023.10.07
Time: 13:54:53
Coding: 8418
Generator:
Coding: 81
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 86
Mileage: 129352 km
Date: 2024.05.15
Time: 07:06:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 91
Mileage: 128613 km
Date: 2023.10.07
Time: 13:56:55
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 86
Mileage: 129351 km
Date: 2024.05.15
Time: 07:03:52
3 Faults Found:
5275220 - Headlight
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 14
Mileage: 128636 km
Date: 2023.10.17
Time: 05:44:34
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 34
Mileage: 128636 km
Date: 2023.10.17
Time: 05:44:37
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 34
Mileage: 128636 km
Date: 2023.10.17
Time: 05:44:37
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 69
Mileage: 128786 km
Date: 2024.02.17
Time: 17:45:43
