Yeah looks like 1 10mm nut and two strips of self adhesive tape according to ErWin
If you are considering messing with the car yourself get on ErWin with your vin and for about a tenner download all the correct manuals for your car from the horses mouth.
Cheers Guys I'd figured as much but was hoping it wasn't glued on as well. Anyone have the pt no for the adhesive if i require it so I get the correct thickness
It is not glue, it is adhesive tape, As above LLL parts have part numbers. There seems to be a kit of fitting parts (17 above) or just the tape (40 above)
From experience, sometime OEM tape is not that good, you can get good 3M or Scotch stuff anywhere. Better you clean it better it will stick.
