On which year car & check your coding is correct.
My car is 2009 facelift model sline. I have checked my coding and from what i can see it is correct but im not sure. This is what i coded:
19 CAN Gateway - installation list - enable 10 park assist
10 park assist -
- enabled bit 4 optical illustration active
Bit 00 - manual transmission
Bit 4-7 - RHD
Bit 0-7 - 05 model audi a3 5 dr S line 8PA
37 Navigation - software coding 0235155
(I couldnt remember what my original value was for the 3rd value so might have made a mistake here but i added +2 to enable optical illustration)
44 Steering Assist - adaptation - installation park steer assist - value changed to 1
For Abs module i saw online that on bit 17 if you enable bit 0 that is to activate pla. Although on my vcds nothing shows for bit 0 its empty and if i enable the coding get rejected. However if i change 44 steering assist value to 0 then i get an error saying request out of range if i try enable bit 0 on abs.
So im not sure what else to do, if you could please help me it would be appreciated.
