Sportback Eibach Pro springs fitted
DEKA1967
Newcastle
I’m after some help at getting the above springs fitted to my 2016 RS3
The car is fitted with Mag ride so this will also need calibrated
Have tried a couple of garages that I used when I had my Golf R but have had no joy
Northeast (Newcastle) area
TIA
You need someone with the OEM VAG software like ODIS IIRC.
You can see the error (or the actual height you can measure against) with VCDS but to correct it you need dealer software so a dealer or good indi.
I'm sure @DJAlix can do it but not sure it is something that can be done remotely.
In order to be able to connect to a car remotely a VAS interface is needed otherwise you would need to visit myself, one of the specialists in my network or indeed an independent specialist.
Reactions: flybynite
Thanks for the reply
I have had it to a VAG specialist who has ODIS etc
He is going to get back to me with a price to fit the springs & calibrate the Mag ride
Where about are you based if you don’t mind me asking?
Or is there any specialists in your network in the Northeast area
I do have a guy in Newcastle but unfortunately he is yet to update his VAS hardware so won’t be able to do this for you. Myself, I am based in north London.
Ok
