Tyres...
rngDeadeye
Oxfordshire
Ok, I know I'm in the minority when I can feel soft tyre walls so I'm interested if any of you are also weird when it comes to tyres.
Admittedly I've only 40 miles but tyres are horrible.
Does anyone else notice that if you're on a dual carriageway doing 70 and you weave the steering wheel left and right it feels like the back of the car isn't connected to the front?
I know it's the tyres as I've taken plenty of sets off after 50 miles because I mistakenly took other's advice.
I guess another question is, do they get better?
I have a sneaky feeling I'll be putting Michelin PSSs on in BMW * rating.
Just been out to check the sizes and noticed they're Bridgstones. I thought these came with Pirelli PZeros
265/35 front and 245/35 rear, is that correct?
They are the factory fit items and sizes are correct
I've found Bridgestone Potenza's to be a somewhat hard compound tire with stiff sidewalls, very noticeable if coming from some other tires.
All new tyres need time to scrub in, 40 miles may not be enough, you are driving on all the casting ridges and not the flat tread, I am always careful for first couple of hundred miles. Try to scrub them flat (acceleration/deceleration and normal driving as opposed to hard cornering) Also play with the pressure, more does not always make the tyre feel stiffer.
265 /30 fronts.
Reactions: rngDeadeye
EvilGT also found that the geometry was off from new and described similar symptoms. Don’t know if that’s also a shout?
Reactions: RS03???
I had difficultly getting anywhere none Audi to check mine. No geo specialist locally that I could find and all the usual suspect wouldn’t touch it because all the adaptive cruise etc should be recalibrated in theory.
Why the wider front tyres ?
265 is a fair bit up from 245 on the rears.
Why the wider front tyres ? 265 is a fair bit up from 245 on the rears.
Hang over from the days when they had iron-block engines and a hastily applied band-aid because they understeered off corners at 9/10 round the Nürburgring. (previous gen was 255/235 not 265/245)
IMHO not needed on alloy engine cars on the public roads and needed even less on the 8Y which is supposed to have the slidey rear diff that magically removes understeer?
Reactions: Charlie Farley
Always been the way with the RS3.
On the 8V they used them (255) supposedly to try quell the understeer.
They still felt the need on the 8Y but went wider whilst increasing the rears from 235-245.
Mine came with Pirelli PZeros and they’re OK. I wouldn’t say that the sidewalls feel soft but I don’t drive anywhere near the limit. On a couple a spirited drives I could feel the car rotate as the rear differential worked its magic but it felt planted. As said, give them time to bed in.
Makes me wonder, if PDI was properly performed by whoever Audi uses, to set the tyre pressures correctly for handover, did they fully remove all the suspension blocks ?
Reactions: Daggerit
Don’t know, but every Audi I’ve ever collected has always had high tyre pressures for whatever reason.
  • Wow
Reactions: DangerMouseUK and RS03???
Pressures are always increased from factory.
Helps especially if cars are stood around for ages.
Reactions: Daggerit
Luckily, not experienced so far by me.
Reactions: Daggerit
I do know that my car never reached the supplying dealer. It was registered at the dock and PDI’d at some “centre” in Corby.
Girl who delivered it picked it up from BCA in Corby.
It felt a little better with a bit less pressure yesterday..
it’s a cracking car though and I know I can fix the tyre issue.
Reactions: DangerMouseUK, Daggerit and RS03???
Good to know, its getting better with correct tyre pressure.
I had an S3 8Y and an RS3 8Y that both threw a please check all tyre pressures yellow warning message shortly after getting them and the pressures were all 2-3 psi above what was on the door card (39 psi front, 35 psi back from memory) wondering if something needs to be set at PDI time as I had two of them throw that error after 50-60 miles of driving after collecting. After correcting the pressures and storing them in the MMI never got another message so no idea what was going on there!
Storing them gives the ECU a datum figure to work from.
29
32
72
5K
32
