LeeboyyRS3
I recently bought a nardo grey Audi rs3 2015 and the front driver wheel sits inwards at The top and is starting to wear away inside of my tyre,any idea what it would be anyone pleasee? Thanks
Upload a picture if you can. How much of an angle?
What do u mean mate? Is Tht a big job?Camber differences, It'll need the subframe moving to align it.
Camber can't be adjusted independently on these. The position of the subframe has an impact on it. So if it's shifted over to one side you'll see one tyre look like it's standing straighter as you have in the pictures. My S1 in the same though not as pronounced. When it was lowered there's a difference between driver and passenger side so it looks like Audi didn't get the subframe positioned correctly when the car was built. the guys who did my tracking couldn't get the front camber/caster sorted (rear is all adjustable on the S1 so that's all good).What do u mean mate? Is Tht a big job?
Thanks mate. Yeah Tht front bumper just needs tighten in the inside,goes in for tracking nextweek so hopefully they’ll be able to tell if the subframe is bent etcCamber can't be adjusted independently on these. The position of the subframe has an impact on it. So if it's shifted over to one side you'll see one tyre look like it's standing straighter as you have in the pictures. My S1 in the same though not as pronounced. When it was lowered there's a difference between driver and passenger side so it looks like Audi didn't get the subframe positioned correctly when the car was built. the guys who did my tracking couldn't get the front camber/caster sorted (rear is all adjustable on the S1 so that's all good).
As to is it a big job, not really. Audi can do it and the tracking but they'll want over £200. Any specialist should be able to do it if they're familiar with the car.
Unless the car's been in an accident it's unlikely to have a bent subframe it may have shifted or not been set right to start with. The mount points have elongated holes to allow for adjustment so they can move. There are centralising inserts available for the MQB platform the will centre the frame and keep it centred but as to whether that is good for you would depend on the rest of the car being straight.Thanks mate. Yeah Tht front bumper just needs tighten in the inside,goes in for tracking nextweek so hopefully they’ll be able to tell if the subframe is bent etc
It was in lastweek getting new front top strut mounts cos was knocking at the front so Thts all sorted now but I’ll mention to my mechanic about the sun frame.there was a thread about a boy having a bent knuckle I thot was maybee that as was exact same symptoms as minesUnless the car's been in an accident it's unlikely to have a bent subframe it may have shifted or not been set right to start with. The mount points have elongated holes to allow for adjustment so they can move. There are centralising inserts available for the MQB platform the will centre the frame and keep it centred but as to whether that is good for you would depend on the rest of the car being straight.
