Yes of course what do you need precisely?Q Is there pdf link, to electrical schematic / wiring diagram ?
Tnx- Graham
Take a look at the link should be something in theregood question , supplies for the rear wing mounted bose amplifier , the head light main beam, are these fed via separate
cct, / relay / fuses etc ?
All the wires connections to the light seem o.k by way of a multimeter or similar?Thanks for that, separate fuse, I some times loose the RH head lamp dipped beam , odd, but returns,
have all the links ,
Graham
I purchased some bi-led units from trups very good so sourced some parts myself and put a couple of sets together much better the hids in my opinion instant on off etc great cut off no glare at any oncoming drivers etc just got a few tweeks to do when I get the time.Yes lights have run for years, there one of the first batch that Tupp's produced , could be the ballast
but , come back and runs fine for months, don't do very much night driving , the lamps are permanently
on, as powered from the dip beam, main feeds the spots and the projectors pick up the main feed , to alter the beam pattern
that and the 7/8 day battery life when parked, something is taking quite a load,
