Hi guys, I have a audi a4 2007 2.0tfsi got the dreaded cylinder 2 misfire P0302 implausible signal,
so far Iv had new spark plugs fitted, and swapped the coils over to see if the code moves over to another cylinder but it still says on cylinder 2
today I had a compression check done on all the cylinders and it was the same across all four approx 120psi which is fine.
So I’m led to believe it could be a faulty injector?
has anyone had the same issue / fault code…?
many advice greatly appreciated
