Auto light and Auto Wiper retro fit guide
Stealth80
Cornwall
Hi all, I've just finished retro fitting auto Wipers and lights to my PFL S3.
Firstly to do this, your car is going to need to have climate control fitted, if not, you will have source and install the loom. I didn't need to do that as I have climate control.
To do this you're going to need 3 parts.
1. A sensor. The standard sensor part number is 8U0 955 559 this is the humidity sensor for the climate control.
For PFL you want to swap that out for a rain/light/humidity sensor part number
8U0 955 559 B, and for a facelift 8U0 955 559 C.
2. In addition to the sensor (if your sensor doesn't include it) you will need to replace the gel pad.
Part number 8U0 955 609. Can get them from China for about £7 or if like me you're impatient, direct from VW for a pricey £40!!!!
3. A switch with Auto position. The switches are going to be slightly different for everyone depending on what lighting arrangement you have. I think they are all a variant of
8V0 941 531 with lettering at the end, mine was a H and I swapped it for a K
(Xenon, rear fogs only)
Ok, once you have your parts, it's time to fit them. Start with the switch, pop the panel off from the drivers side of the dash and and push out the switch from behind, it's pretty easy, swap it over, plug it in and reseat it.
Next the sensor. Pull the rear view mirror off the mounting. Once off, with your fingers, squeeze the housing trim at its widest part and pull the narrowing section away. Then pull down on the remaining half cylinder shaped section.
Look at the mounting, twist it off it's lugs and pull down.
Use a small pick or screwdriver to oish in the connection tab and pull the connector from the sensor.
Unclip the silver clips either side of the sensor and pull the sensor away from the housing. Clean up the windscreen
Now put your gel pad on your new B or C sensor and do the reverse of the above.
Now for the coding, this is why I thought I would do a guide cause there's a few options you need to sort to make this work without errors. I had a lighting malfunction light on the dash with no OBD fault codes...
Reactions: Angelina_Filipova113
Coding
First place is the lighting module, in there is a setting for rain sensor, enable it
The rest of the coding is all done in module 9, the central electrics.
Firstly, let's tell the module we now have a rain/light sensor
Next activate the one circled, this is the setting that was causing my lighting malfunction dash error
From here you should now have the auto lighting feature available on the MMI. For Auto Wipers put the stalk at the first setting and that's done, lights into auto.
If you want welcome and coming home lights then you need to go into the adaptation settings in module 9 and find comfort lighting
Once in there enable coming and leaving home and choose a time in secs that suits you. Change the top setting to automatic.
Once done you should now also have welcome home and leaving home options in the MMI
Nice writeup, well done
Reactions: Angelina_Filipova113 and Stealth80
I followed this guide recently and it all ended up working perfectly so thank you OP for this.
A couple of notes for anyone else though.
The first screenshot showing "rain_light_sensor" ... I couldn't find this anywhere in my Obdeleven Pro so I skipped that and continued on. It worked anyway so perhaps that setting isn't there any more?
Also I tried to get away with using a cheap Pro Scan obd device with Carista and Carly but they didn't do long coding so I had to get the obdeleven device and buy an obdeleven Pro subscription.
All in all very happy with the end result. Auto lights and wipers working perfectly.
Reactions: Stealth80
I wish this was on here when I started mine. I did the hardware without tutorial but I couldn't get the coding to work for months. Admittedly I only tried every 6 weeks or so.
