Xerxes_VII
Hi Guys, first post here, so sorry if formatting is incorrect
Have a 2006 Audi A3 2.0T
Engine code - AXX, BPY, BWA, CAWB
Twice in the past 2 weeks the oil pressure warning light has come on, noticed if you drive normally the light does not appear (can even do 70mph fine) also checked the oil level twice since the issue appeared and it is fine
The light only seems to appear if you really put your foot down quite a bit - for example blasting it down a strip of dual carriage/road (each way)
Hopefully the above might be a good indicator of what it could be
possible causes
oil pressure sensor - think if this was the case the light would come on even if driving normally
oil pickup pipe/sump - Leaning more towards this and getting it cleaned
oil pump - car is not making any strange noises, sounds normal, also would the light not appear more frequently?
Any advise would be appreciated
Thanks,
possible causes
Thanks,
