High beam assist cannot be reached problem.
Ivan.p
Bulgaria
Hello everyone,
I know that this topic has been discussed many times, but I do not find the information I need.
I have an audi a3 8p, 2012.
I'm trying to retrofit a high beam assist mirror. What I have available is:
My old can gateway from my own car: 7N0 907 530 N
HBA mirror: 8K0 857 511 E
extended can gateway (I bought it from a scrap car): 7N0 907 530 Q
momentary stalks.
I am trying to connect the mirror to the can gateway, pin 3 of the mirror, I have connected it to pin 16 of the can gateway module.pin 8 of the mirror is connected to pin 6 in the gateway module. The cables are a twisted pair. When I encode the can gateway module with VCDS, I select 20-high beam assist in the installation sheet. And in the bcm module I encode on byte 11, high beam assist installed. After scanning with auto-scan I get errors in the gateway module, in bcm and in the high beam assist module. In the can gateway the module writes to me that there is no communication / signal with the high beam assist module. The bcm module tells me the same thing. And on the high beam assist module it says: status: cannot be reached 1100. But there is one big one, but when I enter the select module and select 20-high beam assist, the module loads me, and I can encode it. But it doesn't really work. Does anyone have any idea what the problem might be? I tried a lot, but nothing worked. I look forward to your advice. Thanks in advance.
8k0 is not the correct mirror for a start iirc, subject to checking etka.
Did you connect to the correct bus, iirc it's the drivetrain bus.
Yes, I know this is not the right mirror. The correct mirror is 8p0, but I could not find one, hoping that it will work and there will be no problem, I bought 8k0. I think I tied it in the right places, but I'm not sure. 16 pin and 6 pin from the gateway connector. With VCDS I manage to access the hba module and change its coding, but I fail to activate the assistant, high beam assist: systems fault appears on my dashboard. And when I start auto-scan, I get an error that it can't be accessed.
PS: the HBA module is coded with a distance monitoring assistant. And I think if it is coded not to have this assistant, will it work? If anyone has the opportunity to help with coding?
I am worried whether the hba module is connected correctly to the can gateway, because in some schemes it says that it should be connected to 7 and 17 pins, and in others to 6 and 16 pins. Can anyone guide me? Also now I checked the measuring data block of the high beam assist module that the bcm module does not communicate with the mirror. When I turn on reverse gear or the lights, nothing changes there. Attaching a photo
I'm posting log file from auto scan in vcds. Any hope it will works?
Code:
Saturday,07,May,2022,19:27:56:49356
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2
Data version: 20211205 DS330.0
www.Ross-Tech.com
VIN: WAUZZZ8P0CA165450   License Plate: HBA
Mileage: 229350km-142511mi   Repair Order:
Chassis Type: 8P-AU35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 25 37 42 44 46 47 4C 4F 52 56
          61 62 72 77
VIN: WAUZZZ8P0CA165450   Mileage: 229350km-142511miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PP    HW: 03L 906 023 KS
   Component: 1,6l R4 CR td H43 6948
   Revision: --H43---    Serial number: AUX7Z0L4FN80D0 CVN: FF24404D
   Coding: 00114036032401080000
   Shop #: WSC 06314 000 00000
   ASAM Dataset: EV_ECM16TDI02103L906023PP 003007
   ROD: EV_ECM16TDI021_AU35.rod
   VCID: 03D60C62411C1368A7-8056
   VINID: 9D196AAAA2200134411851050082FA9618
No fault code found.
Readiness: 0110 1000
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 11422012092800FF880F04E9901900513F0C00
   Shop #: WSC 06314 123 12345
   VCID: 7B4E1C8A29F463A0E7-802E
Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0180
   Revision: 000637      Serial number: 8P0820043BM
   Shop #: WSC 00000 000 00000
   VCID: 78436281FDE5519FCF-802C
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 N    HW: 8P0 907 063 N
   Component: BCM PQ35  M   110 0667
   Revision: AJ110667
   Coding: 46000A2FEC133AC0207040E82100815C46FA29AA016DC12AE400CF800041
   VCID: 3F0A943E59C88B0C87-806A
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00D133
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 024C2D
1 Fault Found:
03395 - Control Module for High Beam Assistant
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 229350 km
                    Time Indication: 0
                    Date: 2022.05.07
                    Time: 02:08:45
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.30 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 M    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0140
   Revision: 11001001    Serial number: 36861211800633
   Coding: 100003
   VCID: 481382117DF5B14F4F-801C
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
   Component: Airbag AU1042 H10 0250
   Revision: --------    Serial number: 003JU0075AZN
   Coding: 30314238303830303035554A304C38503053
   ASAM Dataset: EV_Airba10AURB4 001001
   ROD: EV_Airba10AURB4.rod
   VCID: 5219AE778DA775811F-8006
   Crash sensor for side airbag: driver side:
   Serial number: 3572DRB400007AC86A73
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 3582DRB400007AC9220T
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 35128RB400006ADEB5D4
   Passenger side rear thorax airbag crash sensor:
   Serial number: 35228RB400006ADFA9EA
   Crash sensor for front airbag: driver side:
   Serial number: 35547RB400006B96F8D5
   Crash sensor for front airbag: front passenger side:
   Serial number: 35647RB400006B81D94X
Address 16: Steering wheel        Labels: 8P0-953-549.lbl
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Component: J0527           H38 0070
   Coding: 0004042
   VCID: 4615862BB5EBBD3DBF-8012
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           H02 0100
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 932 N    HW: 8P0 920 932 N
   Component: KOMBIINSTR. VDO H04 0150
   Revision: D0H04003    Serial number: 2244L003078302
   Coding: 0276128
   Shop #: WSC 00046 000 00000
   VCID: 3F0A943E99C88B0C87-806A
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway H41 1623
   Revision:   H41       Serial number: 110112F6000361
   Coding: 352102
   Shop #: WSC 05314 000 00000
   VCID: 3E0D963355C38DF5FF-806A
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 229350 km
                    Time Indication: 0
                    Date: 2022.05.07
                    Time: 02:08:51
Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.clb
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 E
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 01018B6B74745D545420363E
   Shop #: WSC 02313 785 00200
   VCID: 3306ECD2090C33B827-8066
1 Fault Found:
02001 - Data-Bus Automatic Distance Regulation
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Revision: D0H04003    Serial number: AUX7Z0L4FN80D0
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 193 G    HW: 8P0 035 193 G
   Component: RNS-E PU EU     H06 0220
   Revision: 0000012S    Serial number: AUZBZ7MD208618
   Coding: 0225757
   Shop #: WSC 01901 995 101652
   VCID: 3407EADDCD11C9B32F-8060
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 P    HW: 8P0 959 801 P
   Component: Tuer-SG         H04 0101
   Coding: 0135420
   VCID: 48138211BDF5B14F4F-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 232    3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3702E4C6F920DBC4C7-8062
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158230506388
   VCID: 3605E6DBF51BDDCD3F-8062
Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 1K0 907 951
   Component: EZE_2         H41 1623
   Coding: 00000000
   VCID: 6F3A74AE1938AB5C07-803A
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 8P0 959 802 P    HW: 8P0 959 802 P
   Coding: 0135676
   VCID: 4910801CA1FA4F4657-801C
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0225757
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H41 1623
   Coding: 030F185A
   VCID: 7138709401C2BF6E17-8024
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900935744
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0131288
   Shop #: WSC 06314 000 1012544
   VCID: 42098E2785D795119F-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0131288
   VCID: 43168C2289DC9328A7-8016
Address 77: Telephone        Labels: 8P0-862-335.lbl
   Part No SW: 8P1 862 335 A    HW: 8P1 862 335
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005532645
   Coding: 0011422
   VCID: 3504E8D8F116C7CA37-8060
1 Fault Found:
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 229350 km
                    Time Indication: 0
                    Date: 2022.05.07
                    Time: 02:08:45
End-------------------------(Elapsed Time: 02:53)--------------------------
I bought the right mirror, 8p0 and now everything works perfectly. I only have one question, because I want to connect 6 pins of the mirror to the lighting ceiling, so that it does not get dark in the evening when the lighting is on inside. The socket on the lighting ceiling is 12 pins, I found that it should be connected to pin 1, but there is no result. I will attach photos of the socket, which is on the lighting ceiling. I will be very grateful if anyone can help me.
