ABS pump replacement possible VAGCOM expert needed
mephisto
I had some ABS errors due to ABS pump signal. ABS light was stuck on all the time.
Ive now replaced the pump which is fine until i drive the car above 5/10mph the ABS light comes on. If i stop and turn the engine off and back on it goes away.
Do i need to code the new(2nd hand) pump in? Anyone in Dorset area a VAGCOM expert up for doing?
Never done an abs pump but would expect, like most modules, coding and adaptation to match your previous pump and possibly component protection will need removed cause it’s second hand.
You also don’t mention what car as older cars will be less sophisticated and need less coding than newer cars.
OK thanks for your input happy to supply all of that to any interested party.
Audi S3 8L (210bhp Prefacelift) V reg
