Sportback Spacers
Csllover
Member
Vaud
Could I please have a quick opinion on the spacers I’ve fitted? 15mm all round. Staggered, factory wheel setup (including p zero tyres).
Nice, but be prepared for road rash behind them on the bodywork.
I’ve just noticed the fronts are rubbing so they will have to go. Will try 12.5mm. Hopefully enough difference to not rub?
On my stock wheels I ran 13mm up front and 16mm on the rear. I don’t think the 15s would rub up front unless you’re really really low. If it’s rubbing swap the front for a 12-13mm and should be good
Reactions: Csllover
It normally rubs on one of the arch screws on the front. If you remove it, it should stop the rubbing. :)
They just rub under braking, will have a look. Thanks
Reactions: jimojameso
604
668
