TTRS buttons install to RS3 FL wheel
8YARWY
Electric Avenue
away
I’ve put together this guide to aid anyone wanting to do this themselves.
1) Remove battery connection
2) Remove steering column top trim
3) Remove and disconnect Airbag place to one side
4) Remove black centre circular trim / wheel buttons by inserting trim tool to pop the button parts first, then gently lift the T shaped clips inside around the circumference inside, once free you can unplug all the white multi-plugs from it.
5) Once you have the black wheel trim off you’ll see the recess part where the buttons go
6) you then need to put the plastic guide into that recess to mark the hole / cutout positions ready for the Dremel works.
7) then cut out for the screw holes and connector slot with the dremel
8) the buttons have locating tabs/hooks on the rear, use these to locate the button then put the plastic shim back in on the inside and use the screws to fix the button to the wheel trim.
9) repeat for the opposite side then you’ll have this.
10) Clean off the plastics from the Dremel works and then plug in the wiring loom that comes with the buttons Kit/ reconnect the paddle connections etc
11) Connect up the airbag loom / black connector, re-seat the black connector in its foam cut out at the back.
You need to make sure all the extra wires are out of the way of the airbag, otherwise it won’t sit properly in the recess and your horn might not work.
12) everything back in
13) Pop out the DSG gaiter trim and pull it up out of the way, then Pop up the centre console trim by inserting a trim tool in the gap
14) locate the Start button multiplug and remove it. Then slide it out of the plastic cover by pushing down on the locking tab
You’ll then see the numbered plug
15) The kit has 2 wires that piggyback into this block so you need to remove pins 3 & 6 and insert the 2 wires with the female connections on into this block, like this
The 2 wires you removed from 3 & 6 go into the New button loom blue connector.
Refit the black plastic connector cover for the start button and plug it back in.
16) The wireless receiver needs 12v and earth so I used the handbrake switch multiplug as a feed and there’s an earth point bolt /nut below the DSG lever
17) once the 4 connections are made you can then tape everything up / plug in the receiver module to the loom, then tuck the wires back into the centre console out of the way.
Once you reconnect the battery you’ll see a light flash on the blue covered receiver module, to let you know it’s operating.
18) once you are happy refit the console trim and DSG gaiter then test the 2 buttons on the wheel.
Any questions just shout.
Reactions: EBakken, NevMan, EdmundVR4 and 11 others
Here’s demos of the speed of the Drive select button operation.
Reactions: DW81, Sandra and Count Drunkula
Impressive skills!
TX.
Reactions: jimojameso, 8YARWY, garethdj and 1 other person
Absolute legend Sir for taking your time to post this info ,nice one .....
Reactions: jimojameso and 8YARWY
What's the button quality like? OEM levels?
I’d say so.
A friend bought some and says they are pretty much the same as OEM
Start button has a double action so you can’t accidentally press it.
I don’t think you can go wrong with these.
Hey T-1000,
I'm currently installing these but I have no idea on how to tap into the handbrake switch multiplug... Any chance with your experience be able to show us how to do it?
Hey T-1000,
Locate the 12v feed cable in the multiplug wiring and tap into it.
I just gently cut the sheathing to expose the cable then tapped into it.
D
635
Deleted member 117185
D
D
D0C
