Hi there,
First post. Back in the Audi camp with a 62 plate TTS - just put a deposit down today. I’m stepping down from a CarPlay setup with DynAudio so need to improve the ICE setup a bit without spending too much.
I’ve had Dension gateways before - generally good but expensive and buggy. I really want a reliable solution where I’m not trying to drive and cycle BT on/off or pull over and reboot the car so get the thing to work.
The TTS comes with a Navigation Plus unit (I believe also called an RNS-E) which seems the same as our old Seat Exeo - i.e you could use BT on the phone but for MP3 you had to use SD slots behind the screen - no BT audio. This one also has a Media button.
Also been reading about different version a of the RNS-E but have no idea which one would be in a 2012 registered car.
Currently looking at a Tune2Air but have some questions:
1. Is it reliable compared to alternatives (if not what’s best)?
2. Unfortunately the new car has a CD changer rather than an iPod socket in the glove box so I think that means I won’t have an AMI cable (unless the CD uses an AMI cable)?
3. Wishful thinking but just wanted to check that a 2012 model would still definitely not support Bluetooth music (I’ve heard of some kind of oem Bluetooth on specific car models and a discontinued aftermarket Audi accessory)?
4. Assuming all the above is correct then will I need a wiring loom like this?
https://www.ebay.co.uk/itm/Adapter-...-/265013173589?_trksid=p2349624.m46890.l49292
...and the tune2air just plugs into the AMI socket on the end of the new loom?
Really appreciate any help or advice. And if anyone has bits for sale, please let me know.
Thanks,
Ed
Thanks,
Ed
