Audi badges
D1RZH1N1S
Chatteris
Hello fellas,
Is there any nice way to remove these badges? Thanks in advance!
I've just done mine to black rings/badges... Easiest way is heat gun if you can get your hands on one, failing that a hair dryer will do. Some bug/tar remover (I used autoglym) to help and plenty of elbow grease to polish off the excess glue.
I've done it with wd40, leave to soak in then pour boiling water over it...badges mostly then peel off. Then tar remover for any tougher parts.
Reactions: Gazwould
Nail varnish remover is also a great way to remove glue. Just ensure that you wipe up all the spills etc. A platic blade is also very useful; search Amazon/ebay. Would link but they don't always function correctly in these threads.
Oh and don't try to combine the hair dryer/heat gun and varnish remover methods (i'm sure you wouldn't!).
I always use a toffee wheel for this
Heat with a hair dryer, use some nylon fishing line in behind the badges, work it from side to side, then tar remover to get rid of the glue.
JG
9
953
78
16K
24
20
3K
