Hpfp question
Donfero
For the guys running stage 2, is the factory hpfp enough or did you upgrade. My car just will not give me a break! After fixing the low boost problem now im having low fuel pressure!!
Sent from my TA-1004 using Tapatalk
Are you getting problems with the injectors because of the hpfp?
Not sure where the problem is, but its on the high pressure rail
I know that hpfp’s can fail also cause low fuel pressure. Have you got vcds or obdeleven?
You need to upgrade the HPFP internals, I have Autotech upgrade.
Reactions: Donfero
Yes I do. Vcds.
6K
P
13
610
Pedrödelabongo
P
908
