Underneath View
audiwaterpump
walsall
Your comments and opinions please:-
1) Red Arrow. What is this, and what's it for?
2) Green Arrow. Is this the exhaust bracket that rusts?
3) Blue Arrow. Anyone placed an axle stand here?
4) Pink Arrow. Good place to place an axle stand.
AudiUnderneath
Red arrow = tranny mount.
Blue arrow - sorry, I do not know. Living in AZ rust is not a thing for me, plus I have changed out my entire exhaust system.
Other arrows - I've never used those locations for stands. The front one, IMO, would impede wheel/axle travel. I just use the body jack spots and have not had issues.
Reactions: audiwaterpump
Red arrow is gearbox mount.
Blue arrow if you are talking about the bolt that secures the lower arm then yes that is where I always put the axle stands.
Yes, the bolt(s) that secure the subframe to the body, next to the big control arm.
It seemed a bit insecure to me, as it seems it could slip off the axle stand easily.
I would of preferred if it had been a snug cradle fit on the axle stand, similar to point 4 at the rear.
I haven't had any issues yet. I use this type of stand.
Reactions: KSigota and audiwaterpump
Factory jack and load bearing surface.
I don't have photo's, but if you look at the profile of the factory jack and the area just behind the pinch weld.
The loading surface is not the pinch weld, but the slightly raised (or lowered) area just behind the pinch weld. Ideally, this where you would want the weight of the car to be supported.
But in the real world, many people (and these tyre/service places) will just jack up on the pinch weld.
I agree, with my "modified to suit" bits, I only use the folded vertical section to provide stability/location.
