Hi Guys, after a little help/advice please ! I have a manual 2015 and I had the clutch slipping. I changed this for an uprated 4 paddle Sachs with a new flywheel and slave/release bearing. Changed gear box oil and bled clutch, all was well for a few short drives apart from a little noise in neutral which is normal on these ? Now it won't go into gear at all while running, start it up in gear and it's trying to pull away. Is this the slave or the clutch ? I've bled new fluid through it etc and it works ok when the cars cold but as soon as it warms up it gets gradually worse ? Is this a gearbox off again job ?
