Random Gardening Question
kolash
London
How would you remove this quickly without something major like a mechanical stump grinder?
Dig it out.
And don't.......
Sent from my SM-N9600 using Tapatalk
Reactions: kolash
best plan would be to dig around it, not too close to the trunk itself as there will more roots to deal with and it will make the job harder.
So dig around the stump further out to expose the side roots , get a sharp axe on them , work you're way around the stump and you'll find it will loosen up very quickly, there will most likely be a central root aswell that need chopping before the root will just pull out.
Not a massive task as it's not really a massive root.
A morning's work with ease.
Lol, digging and cutting roots could take all day.
I’m a gardener and depending on what sort of tree it was could be a mate as some roots go straight down.
hire a stump grinder and should take no more than a hour and no heavy work other than using the machine which will grind it ground level.
Reactions: kolash
The OP does say without either of those methods....that doesn't really leave much choice does it.
Reactions: kolash
looks to be a shrubby plant more than a tree , probably with an old climber mixed in with the stems.
A close up pics does indicate a lot of old decayed wood etc , cant see it taking more than a mornings work with a decent axe and spade.
Reactions: kolash
It’s really not that hard with a stump grinder and should cost around £50
Reactions: kolash
Mini Digger if you have access for one , 10 mins max job done.
Reactions: kolash and martin1984
If that's one of those shrubs with the yellow coloured wood (can't remember name) then it will be an utter pig
I had one that the OH wanted removed and it took one sharp and heavy axe coupled with a course blade on a rip saw, best part of several hours if I remember as the roots go everywhere and lots of closely packed branches coming up! Oh and some long armed croppers came in handy too..
Reactions: kolash
Thanks all. 2 men, mattock, axe, saw and a few hours work got the job done!
Reactions: Pinky1959 and Charlie Farley
20
986
477
14
109
8K
