Lower door mouldings
HOGG
GB
Does anybody have the four part numbers to hand for the lower door mouldings for an S4
Please
Sent from my SM-G930F using Tapatalk
And if your are looking to fit used oem S4 blades make sure you have a good look at the metal retaining hardware on them, they rust , in turn expand due to corosion and then distort the ABS back section .
Also make sure the plastic mouting rail has intact clips otherwise the blade wont fix to the door properly or securely.
I bought my set from a guy in germany for a lot less than normal used prices , still a lot for what they are but not the silly prices ebay ones are.
I had to rebuild one but I knew that when I bought them.
IMG 0864 1s4
IMG 0864 1s4
IMG 0873
I'll sortout the correct p/n for you chap, no charge...:yes:
Reactions: HOGG and Ricky Burrows
