Retrofit CarPlay
The menus on the new MIB2 units are different. For example, on MIB1, you press one of the silver buttons to go to the menus in the corners. On MIB2 you don’t have that, you just have 1 bit on either side of the screen which you press one of the 2 big silver buttons to get to. So basically without it you can’t navigate the menus on the screen properly.
Just a word of warning, I changed the system as you’re going to do, but the illumination at night on MIB2 controller is white. The rest of the prefacelift buttons and switches in the car are red, so it won’t match. White looks a lot more modern, and if your OCD is anything like mine and @larbel then you’ll be changing them all too! I actually swapped all mine are for very little cost as all my old units sold
Reactions: sparkymark75
Not sure whether to thank you or not for that! My OCD might be triggered! Is it just the lights on the MMI controller that will be white?
Not sure whether to thank you or not for that! Is it just the lights on the MMI controller that will be white?
Yes. So they’ll be white and the rest of your lights in the car will be red....it did my head in! But it’s pretty cheap to do the conversion! drive select bar, reading lights front and rear, cigarette lighter light, window switches, mirror switch, headlight switch, handbrake switch, auto hold switch if you have it....air cons controls...oh and the steering wheel. The steering wheel swap to a facelift one sets you up for virtual cockpit too if you want to swap it!
I should pay attention and it may be because I’ve not really driven my car in the dark for a while but I’ve never really noticed my interior lights were red!
You don't happen to have the part numbers handy do you? I can get the main part number, it's the specific revision of them (the letter) I struggle with.
I don't plan to do these now but I do need to buy a new electric parking brake switch as the MMI controller I was going to purchase doesn't include it and if I use my current one, it'll be red! The part number I have for the parking brake switch is 8V2 927 225 C
So, got all this fitted on Saturday. Never touched the trim on an Audi before so took my time as I didn't want to damage the soft touch plastics or any of the clips. Took me about 4 and half hours. Everything seems to work okay with the exception of the sound settings. Prior to the retrofit, I had the following options...
After the retrofit of the MIB 2 unit, I now have the following...
The guy that supplied the unit reckons my amp just needs parameterized. I have sound, just no ability to tweak it.
For anyone else stumbling upon this, I used the following items;
  • MIB 2 Unit (8V1 035 035)
  • Connection for external audio sources (81A 035 736)
  • Stowage Compartment (8V0 863 300 C)
  • Adapter Cable Loom (I think the official part number for this is 8P0 971 767 however I bought a loom from eBay that @Boj27 pointed me to)
  • MIB 2 MMI Controller (8V0 919 614, this will have two letters at the end. I believe BE - is no touch/no keyless, BK is touch/no keyless, not sure what the others are)
  • Standard size fuse adapter to power the USB ports.
He’s wrong... PFL B&O amp won’t accept new parameters; you’ll need FL B&O amp to get back your controls, and depends on the MMI version you have; you might or might not be getting sub control back...
Just saw you have sub control right now, so looks like you just need a new amp and sub would be fine.
To be fair, he only suggested this might be the solution and was going to check with a colleague.
Th easy bit is getting the amp, the trickier bit is getting to an Audi dealer to get CP removed. Can this be done remotely by anyone?
Some Audi dealers will remove the cp as long as it’s not a stolen part. Difficulty is proving that.
Other problem is you are not replacing a broken part with the same part so most dealers will have limited skills or would be willing to do it.
Just noticed you are in fife. @DJAlix might be coming up for DH rolling road day so maybe it’s something he can do for you.
Hopefully the guy doesn't take too long in getting back to me and if I need to get a new amp, I can source one in time.
The thing with all of these issues is there's never conclusive information one way or another until you try it. Surely the fact I get sound means it's compatible on some level with the MIB 2 unit.
No, it's confirmed hardware differences and the FL amp won't accept new parameters, it works but you won't get the controls.
Contact D H Automotive as they can host a remote session with me. DH are site sponsors.
Last night I finally fitted the MIB2 version of the B&O amp (after much comical fumbling with the connector!, stop laughing @Boj27)
As anticipated, CP kicked in so I’m only getting sound out the drivers side speakers. Even though I’m only getting half the sound, I can already tell the fullness of the sound is back.
@DJAlix - I’ve booked my car in with DH Automotive on Monday to get the CP removed. Would that be yourself doing that?
I would assume so but have not been booked as yet. Am doing a Q7 engine ECU for them at the moment so will ask once the works are complete.
Where did you source the parts from?
Edit: will be me doing the works
The MIB2 unit was sourced from Vagtec. The B&O amp was sourced from a breakers yard on eBay. The rest of the fixtures and fittings were either eBay or Audi direct.
Everything seems to work, besides the sound issue with the B&O amp because of CP. I do have a few error codes being flagged up. Some are CP, 3073, 3084 and 3077 in the 5F module I'm guessing are because it's coded for Audi Connect but my car didn't come with that so doesn't have the necessary cables fitted. I'm not sure what 6696 and 7226 in the 5F module are however.
I've included a VCDS scan of my car so you can see what I'm referring to and to allow you to ask any questions before Monday.
Code:
Wednesday,11,September,2019,13:52:47:30103
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8V4G*******   License Plate: KV15***
Mileage: 73959km-45955mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 20 22 42 44 47 52 55 5F
          A9 BB BC
VIN: WAUZZZ8V4G*******   Mileage: 73959km-45955miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 F    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0A1D00122466010B2004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259F 001004
   ROD: EV_ECM20TFS0205G0906259F.rod
   VCID: 43D34EAF7B12816F97B-8016
No fault code found.
Readiness: 0010 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 5046
   Revision: 06354004    Serial number: TFK01608311647
   Coding: 0014
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 53F37EEF8B7211EF27B-8006
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 L    HW: 3Q0 907 379 G
   Component: ESC           H42 0722
   Revision: 00000000    Serial number: 61395000000852
   Coding: 31F193A254212A6D0178070241C3698CC92A5480E08296F6184150F48208
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-043.clb
   Part No SW: 8V0 820 043 D    HW: 8V0 820 043 D
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000659335
   Coding: 03100014000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
   ROD: EV_AirCondiFrontVaAU37X.rod
   VCID: 33331E6F2BB231EF07B-8066
   Relative humidity sensor in fresh air intake duct:
   Subsystem 1 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: 18680FA7000000000001
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0173
   Serial number: 01061515402949
   Coding: 07141B46C24122F503804004B11807A80000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 015001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F9C8719BE1B3F9D7-805C
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150529  041 0585
   Serial number:         150602054254
   Coding: 0A47F7
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 24009040
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Component: E1 - LDS MQB  H05 0032
   Serial number: 31 03 2015  00000562
   Sensor For Anti Theft Alarm System:
   Subsystem 4 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY151040AL8
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000032632014
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000BZ2EQ00000
   Coding: 901E00
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 K    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0054
   Revision: --------    Serial number: 39391514302660
   Coding: 0070051011
   ASAM Dataset: EV_EPHVA18AU3700000 002026
   ROD: EV_EPHVA18AU3700000_002_VW37.rod
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 N    HW: 5Q0 907 567 N
   Component: ACC3          H10 0400
   Serial number: 04051503030959
   Coding: 003E1301FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 46D557BB4820B447B05-8012
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       270515021
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    014 0385
   Serial number: 003MMR03JWSR
   Coding: 98CCC0000C0000005C5400CA00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 005981A32A845A77CA9-8054
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 002 805 15
   Component: SideSensor_Df  001 0887
   Serial number: 357670000007DC3CA49C
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 002 805 15
   Component: SideSensor_Pf  001 0887
   Serial number: 35867000000CE51CA49A
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 402 605 15
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502C11A2DCD5214C
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 402 605 15
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502C91A14CC3A3FT
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 480 402 502 15
   Component: FrontSensor_D  001 6149
   Serial number: 3556502C31993FB0327F
   Coding: 2D2D2D
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 505 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502C51A87874907H
   Coding: 2D2D2D
   Pedestrian Protection Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 505 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502BF1A8787453EX
   Coding: 2D2D2D
   Pedestrian Protection Driver 2:
   Subsystem 8 - Part No SW: -----------    HW: 480 001 202 15
   Component: PedPSensor_D2  001 0887
   Serial number: I0M800000002BAD8231C
   Coding: 2D2D2D
   Pedestrian Protection Passenger 2:
   Subsystem 9 - Part No SW: -----------    HW: 480 001 202 15
   Component: PedPSensor_P2  001 0887
   Serial number: I0N8000000004BC82314
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 8V0 953 521 ER    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 08051504220411
   Coding: E018
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_010_AU37.rod
   VCID: 0E45AF9B60D03C07485-805A
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 8V0 920 972 A    HW: 8V0 920 972 A
   Component: KOMBI         H03 6420
   Coding: 278D180A3F8026000181EA001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 3C21355306ECFE97D61-8068
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 01061510800290
   Coding: 030100043F085A005B0002789C0B00000001010000000000000000000000
   ASAM Dataset: EV_GatewConti 013020
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E07765466FDFE9F-8020
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Component: E221 - MFL  H02 0014
   Serial number: 19 05 2015  D0044603
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001505230842
1 Fault Found:
15360512 - Component Protection
          U1101 00 [009] - Active
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 195
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:08
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 8S0 857 511 C    HW: 8S0 857 511 C
   Component: FLA           H09 0003
   Revision: AA001001
   Coding: 0202010700000100000001
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 392F2C4709DECBBFCD7-806C
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7083
   Serial number: HA1-00023.12.16
   Coding: 0001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004.rod
   VCID: 4ACD638B5C38502754D-801E
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 120515BEA05808
   Coding: 005D8A205C01040000001003
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 K    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5072
   Coding: 8107
   Shop #: WSC 25983 001 1048576
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D334B0CD8C0A7C4D-806E
Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAH5F01BKZH
   Coding: 0173030000AAAA2AAA0000010000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2411ED339E5CA6578E1-8070
1 Fault Found:
15360768 - Component Protection
          [Anti-theft protection - component protection active (0xEA6300)]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:07
                    Voltage terminal 30: 12.0 V
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 210515BEL10041
   Coding: 005D82205E01040000001003
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42DD4BAB640888679CD-8016
Address 55: Headlight Range (J431)       Labels:| 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 01A6000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB.rod
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 8V1 035 035 C    HW: 8V1 035 035 C
   Component: MU-P-LND-EU   055 1168
   Serial number: A698L0JS032233
   Coding: 017351010000000011111102000A00332F0027E701700100DE
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
   ROD: EV_MUHig6C3Gen2HBAS_AU37.rod
   VCID: 323D1B6BD4A838E70CD-8066
   Data medium:
   Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Serial number: --------------------
   Display unit 1 for multimedia system:
   Subsystem 2 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY2035Q0
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL128031800050673
   Compact Disc Database:
   Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1017
8 Faults Found:
1555 - Check Software Version Management
          B201A 00 [009] - -
          [Check software version management]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:16
                    Voltage terminal 30: 12.2 V
                    Status_Software_Version_Management-module_name: MFC2L37xE/FCP
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
          [Anti-theft protection - component protection: no basic setting or basic setting incorrect]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:10
15361024 - Component Protection
          [Anti-theft protection - component protection active (0xEA6400)]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:10
3073 - Cellular Antenna
          B1053 13 [009] - Open Circuit
          [GSM/UMTS aerial - open circuit]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:10
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:10
3077 - Telephone baseplate
          B1051 13 [009] - Open Circuit
          [Bracket for mobile phone holder - open circuit]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:09
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [009] - No Communication
          [Control module for instrument cluster display: no communication]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:38
7226 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Pedestrian assist (0x3A) - function restriction due to communication error - BapErr_retry not successful]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 73935 km
                    Date: 2019.09.10
                    Time: 18:59:12
                    BAP-BAP_Function_ID: 02
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 150515200791
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 7DA7F8575D76379FA1F-8028
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0041
   Serial number: 230515BEM13183
   Coding: 004D82204001040000001002
   ASAM Dataset: EV_DCURearDriveMAXKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
   VCID: 45D750B77526BF5FB9F-8010
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 230515BEM1181C
   ASAM Dataset: EV_DCURearPasseMAXKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 01:52, VBatt start/end: 12.4V/12.4V)-----------
Will only be completing CP on the amp, won’t be touching anything else. Wondering where the part came from in case it flags as unusable or stolen.
Well not sure what you mean by "unusable" but I'd like to hope it wasn't stolen given its from a breakers on eBay. Guess i'll find out on Monday. The way this has went, I wouldn't be surprised!
Reactions: ME CODING
There are a number of reasons as to why control unit might not be able to have its component protection removed, with the top two being designated “unusable” (only VW group knows what this means) or “stolen”. If the unit is flagged for any reason then it will not be able to be used.
You would hope that items from legitimate breakers and business would not be stolen but it happens all the time. I see 4 to 5 stolen parts a day! It’s the risk you take when you go “used”. What’s good is that you purchased from eBay and prolly used PayPal which gives you lots of protection.
I had a kit fitted by HazzyDayz when I was up near Luton. If you need any aftermarket work done highly recommend with great service and I was offered countless cups of tea/coffee.
I bought the kit off eBay and they offered to fit it for £175 whilst doing a reverse camera and parking sensors, I could have probably done it as instructions came with it but thought might as well get it all done at the same time so I don't damage anything myself. The kit was fitted and they checked it launched and I said I'd play around with it when I got home. However after getting home and trying it properly I realised there was no audio. Spotify was playing but no audio at all.
The instructions advised putting phone in debug mode to connect the bluetooth, no such luck. I tried using the aux cable connected to the back of the unit plugged in alongside the USB connection but still nothing.
Yesterday I purchased this device off Amazon as I already had the Audi Music Interface connection and thought it was worth a try. It arrived today with Amazon and I plugged it in, selected the source as Aux and held down the Media button which opens up the Car Play system and the music came flowing through the speakers. No loss in sound quality at all. Only difference between this and the Audi Bluetooth is it does not display the song on the instrument panel and I can't change songs using the volume knob on the centre console but it's easy enough to control or say "Ok Google, Next Song".
If you want Android Auto/Apple Car Play and you've got a Standard MIB Unit with Sat Nav like I do on my 2015 A3 Saloon then I'd highly recommend this as an alternative. I initially had an issue getting contacts to sync for calls but after turning the car off and on again this has now Sync'd.
I've put links in above and hopefully there aren't any issues with that. Any questions please feel free to drop me a message.
I have the 2017 facelift a3; I think I’ll need the steering wheel and VCC just to be fitted. Thanks for all the info though. I’ll check him out
I only got mine last month and being red it was about 5k cheaper then the other models I was looking at and considerably lower mileage. I'd done some research into getting car play/android auto and took the plunge and thankfully it worked out.
Glad to help and hopefully the message won't get buried in the thread
All done. Thanks to @DJAlix and Dave Henderson for getting it sorted. My left ear doesn't feel left out anymore
Reactions: DJAlix, ME CODING and stote
Thank you sparkymark75. I had the standard mmi with BnO i liked the way setting was set like a round type selection. Im just waiting for some pennies to get gen2 amp. I have full sound for now atleast. Did u get a autoscan after your change.
I have VCDS so did many scans to try and clear some fault codes and tweak the coding.
