Hello,
I have had several problems with my *recently* (3 months) bought A3 8l 1.8T. The only big problem that remains is that the RPM starts to fluctuate while pressing and holding the clutch right after boost.
I have a pressure gage that shows when this problem occurs the boost also fluctuates with the RPM. I drew the conclusion that there is some kind of boost leak which alters the pressure to the high-pressure regulator and then the idle throttle motor tries to correct it (I have watched the trend of the TPS-sensor and has seen that the sensor follows the rpm and boost)
Have anyone on the forum experienced any similar symptoms? Or does anyone know what might be the cause?
I have tried to change the hoses to the pressure regulator, tried changing the fuel pressure regulator, and changed one of two hoses to the wastegate.
I am grateful for any help, I really want to start driving this thing after so many problems
