Audi A5 CAPA Stock Vs Revo Vs BSR (stock turbo)
bobby singh
BSR
Gold Supporter
West London & Windsor
Interesting video comparing 3 different tunes.
Spec of car:
CAPA engine
Stock 2260VK
Front mount intercooler
DPF delete pipe
Swirl flap delete
DPF & EGR delete
Stock tune with DPF off (pink) 231hp / 486nm
Revo Stage 2 (blue) 317hp / 567nm
BSR (Red) 326hp / 756nm
Dyno chart can be seen here - https://i.imgur.com/E7U9VIa.jpg?1
Enjoy
Bobby
Reactions: Bishop187, Eric_RS6, Horia and 1 other person
Can't believe the Revo tune doesn't explore the available torque a lot more. A Revo tuned car and one tuned by yourself would be night and day difference with the area under the curve. Even if it was because they didn't want to stress the transmission I would of thought they would be good to go to 650-700Nm. The peak torque on the Revo is only up 15% over standard.
Hi Karl - yes torque was low - as you say peak figures don't mean a lot but the area under curve tells the real story. 80hp more at 3k and now has 300hp from 2.7k onwards.
Reactions: Horia
Great work Bobby , all we need now is a Jack Daniel's Engineering file on to complete the comparison
I'm interested in seeing a similar comparison on a BiTDi A7.
Reactions: Eric_RS6
Do you have such car with a Revo tune? Also, on all Bi TDI's I would recommend a wagner intercooler - they get toasty on the dyno and will show a lower power figure than the road. Assuming temp protection is enabled in the mapping.
@bobby singh is there a chance you could check your mail , had few questions
