Ferg Registered User Joined May 18, 2016 Messages 59 Reaction score 19 Points 8 Location Southport, Lancashire Jun 22, 2019 #1 Could someone please tell me which type of SD card the Q5 (new shape if that makes a difference) takes and also the maximum capacity it will read ? Thanks,
cuke2u Registered User Joined Sep 14, 2013 Messages 13,179 Reaction score 5,344 Points 113 Location East Sussex Jun 22, 2019 #2 It is probably the same as the A4 B9, as they use the same mmi systems: Reactions: Ferg
cuke2u Registered User Joined Sep 14, 2013 Messages 13,179 Reaction score 5,344 Points 113 Location East Sussex Jun 22, 2019 #3 I use micro SD cards with an adaptor where the cards insert from the rear... Reactions: Ferg
Ferg Registered User Joined May 18, 2016 Messages 59 Reaction score 19 Points 8 Location Southport, Lancashire Jun 22, 2019 #4 cuke2u said: It is probably the same as the A4 B9, as they use the same mmi systems: View attachment 185253 View attachment 185254 Click to expand... Many thanks, that's really helpful. Reactions: cuke2u
Ferg Registered User Joined May 18, 2016 Messages 59 Reaction score 19 Points 8 Location Southport, Lancashire Jun 23, 2019 #5 cuke2u said: I use micro SD cards with an adaptor where the cards insert from the rear... Click to expand... Thanks. The owner's manual says not to use those because the card might get detached from the caddy, but I don't think that should happen with normal usage, so one to consider.
cuke2u Registered User Joined Sep 14, 2013 Messages 13,179 Reaction score 5,344 Points 113 Location East Sussex Jun 23, 2019 #6 I know but as the micro card is inserted into the adaptor before you insert them both into the sd slot then I have found this impossible to happen... Last edited: Jun 23, 2019 Reactions: Ferg
