YannisHBG
Hi all,
New to the forum. The luggage compartment light does not come on when the tailgate is opened and neither is that indicated on the instrument panel that the tailgate is open. Have run an output test on VCDS to check the light and it works fine during the test. I have also changed the lock mechanism (albeit to a used one) since I suspected that it could be the microswitch inside it but no luck. Is there anyone who has encountred this before? Yes it could be that the microswitch on the replacemnt lock is also bad but how can I test that?
Thank you all
Thank you all
