The distance is 11cms.
Still not sure I understand because I thought all A3’s had this aerial installed.
Thanks.. over here, none of the PFL 8V has GPS option including S3 or even RS3 so none of them has GPS antenna equipped...
Yes, it’s the FM and DAB aerial as well.
Where’s “over here”?
Bizarre your dash gps is bad, where did you fit it, I would fit a magnetic version in the roof lining, that should work well.
All dash ones I've fitted get plenty of sats so I'm surprised tbh.
Yeah, it's fine when it's out of the A-pillar on the dash itself, that's why I thought a roof mount would be better... But who knows, maybe the dash mount I have is defective and receiving weaker signals?
Maybe something in the a pillar is interfering with the antenna? Wires, airbags?
I would be too scared to drill the roof in case I slippedCould be, but already have the OEM antenna on order so might as well go ahead with it..
