Switched sides from a4 to a6
Plug n pray ???
It’s the same core size as the darkside one for £300. They just have welded pipes and a few brackets on the side, I’ve got some angles coming from auto silicone hoses to do it myself. Then a backbox delete and il put it back on the same dyno as when I mapped it and see what’s what
Reactions: rjwojcik
Bit of trimming I recon and see what it’s like
Reactions: rjwojcik
I had a clean when I did the rs6 grill last year so didn’t look too bad pretty messy behind it though! I need to bosh some brackets up still having some grub and a brew.
Reactions: rjwojcik
That’ll do for now haha could do with making some better brackets, forgot I used most of my bits and bobs when I made the bobber
it’s fairly sturdy though if you wanted you could probably go wider, thicker and definitely taller, loads of room in there! I should have got longer pipes to go between the 45 and the original pipe might still swap it later, I only went and lost the little blue clip for the headlight washer pipe hopefuly il find it tomorrow, don’t even like headlight washers I was going to turn them off on the obdeleven anyway!
Reactions: rjwojcik
Found a better picture
Reactions: Bishop187, DonkeyIce and rjwojcik
Can see the cooler better in person
Reactions: rjwojcik
Very nice A6. I’m looking at get the same 3.0 tdi with S tronic so any advice and things to look for? Must stop read these threads as I’ve got a list of mods already and not even bought the car yet ‍
Reactions: James.c
Not really sure what common faults my sunroof leaked but fixed it, this one had a receipt from a gear box service and timing chain tensioners a year before too because they can tick or something
Reactions: Welshquattro
Can I ask where you got your grill from?
Just from eBay was about £100 you just have to be careful you order the right year pre farce lift and facelift are a slightly different shape
Been a while again just had 4 tyres slapped on got a massive crack in my windscreen and a p040b00 fault come up a while back. Still love the car, and still look at dpf deletes all the time
Reactions: Bishop187 and J10NMM
Bit of an update on the old bus, it’s just hit 140k
Treat it to a nice service, dpf and a map!
Before that though had some trouble with the gearbox. Common fault i think (Coolant solenoid messing up two plugs) also had a leaky injector seal, headlight level fault and some bong eyes old c
opened his van door into the road and smashed my mirror il slap a few pictures on.
290hp was my
Previous tune before the ic and downpipe, this was done in nov 2019 so hats of to my old tuner for it being bang on still
I’m tempted in these, it’s still so quiet but straight through would be brutal, anyone used these before?
