Stronic - can revised box be fitted to older car?
coullstar
Started looking at some S4's and 59 plate one that had a box change about 2 years ago with a new one.
Would this have been with the latest version or is there an easy way to tell?
It should be mate. If you have Carista (iPhone) or OBDEleven (Android) do a full scan and look at the coding on the gearbox, if it starts 8K1 then it's the latter unit, 8K0 and it's the early ones.
You should also be able to check it in the paperwork (if it is there) or call the dealership who replaced it and ask for it.
Thanks, I have full VCDS so can scan quite easily.
So is it likely to be latest revision and therefore less likely to have any mechatronic issues?
Reactions: V6_Man
I would like to think so mate.
Mechatronics was just one of the issues. Some folks have reported that their v1 gearbox with new mech still developed problems later. You'll need to be sure that if the car is being sold as having had the gearbox replaced that it was indeed the whole 'box and not just the mech.
Reactions: V6_Man
From what I've read I don't think you can as there are some differences and the early cars won't accept the later boxes
2010 & 2011 have lower gearing, and can't close the clutches as hard or as fast as the later cars. That leads to less ability to fast shift and launch control not being as aggressive as the later ones.
2012 has the low gearing of the 2010/11 cars, but has better hardware and can grab harder/faster. It fast shifts like the 2010/11, but the launch control grabs harder.
2013/2014 have higher gearing, and the best grab, giving them the best fast shift and the best launch control.
In short, the 2010 and 2011 transmissions are the least beefy and least "grabby" of all of them. They made the transmission better in 2012 and really nailed it in 2013
If you want to know more technical info speak to the guys at Milta Technology as they know these gearboxes iniide and out http://www.milta.co/
Reactions: V6_Man
Thanks, sounds like a new old spec one then.
So will scanning via Carista on Android not work? Just thought I would scan for the hell of it!
Carista works on both but OBDEleven works only on Android.
If you guys want to update the gearbox software to see if the latest software fixes these issues drop me a pm.
I've had mixed results from updating 3.0TDI's with stronic boxes.
Some of these boxes have had 12 revisions of updates
Reactions: V6_Man
Cool, so what type of scan do I need to run then on android? Had a quick look in the service menu but nothing jumped out at me.
I am not sure if the interface on Android is exactly the same as iOS but if you run 'Diagnose' you should be able to see all sorts of stuff in there.
Hi, so I ended up buying the car. Gearbox was indeed replaced in 2017 by Audi. The box has the following number in VCDS - 8K5 927 156H.
Is this box code?
Is this box code?
This I believe is your SW code, what is your HW code?
Here is what came up.
Computer just died and left the lead at work. I'll do it tomorrow.
Reactions: V6_Man
Well I looked into this again and I might be slightly further on my learning curve about this subject but I'm a way off being confident in the answer. I'd like to know more of what Bobby knows because my 2015 S5 'box has version H03 0004 and Tash's 2014 is H02 0002 so I'm not convinced that it's as simple as 0001 is the earliest and 0012 is the latest.
However the 8K5 927 156H code definitely refers to the mechatronic SW and it is the same that would have been used on a 59 plate S4.
(FWIW a 156 is for the EU5 engine and a 166 is for the EU6 engine)
Unless I can find out more about this H0x xxxx coding I am beginning to doubt that it is possible to identify the version of the gearbox from the VCDS scan alone.
Reactions: V6_Man
I completely agree @Dippy hence why I deleted my post last night , which was around would it be worth for example you and I or few others here upgrading to v0012...??
Also, should Doug as part of either the initial Tune or subsequent health checks not suggest us to upgrade to the newer version... And unlike you, it feels to me I have to start the whole learning process from scratch again
Sorry for the confusion I just registered the 156H I didn't read the full number.
8K1927156H - this has 0012 available
8K2927156H - this has 0008 available
There are no release notes with these versions so I don't know what the differences are. But as a general rule I always update the software before doing any tuning to the box.
Two main reasons for doing this:
1) If the car ever goes to Audi for any work there is less chance of them over writing the tuning if the box is already on the latest software
2) This software is like any other software development whereby they contain bug fixes (yes there is a chance they may fix one thing and break another)
Bobby
All I can add is that I see that 8K2927156H is for a diesel engine, and that according to my dealer there were no SW updates for my car.
I can only say 0008 is available.
What version do you currently have?
Bobby - here is mine
Part No SW: 8K5 927 156 B HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H02 0002
Revision: --H02---
Revision: --H02---
0005 is the latest available.
Tbh if you have no issues I wouldn’t worry about it. Updating now means remapping the gbox controller again.
Reactions: V6_Man
Hi, scanned again tonight and then also looked at the Advanced ID section of the module.
So this indicates a build in 2015 and the last flash update in 2017.
So do I have the earliest mechatronic version then, the problematic one?
Also can you tell if the box is same as would have been taken out or any updates applied?
The only way I normally tell if its gen1 or gen2 is by using my programmer to determine which driver reads the controller.
8K5927156H has 0009 available - you are currently on 0001
Reactions: V6_Man
To be honest I'm a little more interested in hardware part. I believe there was an updated version with extra filters that could be changed from the earlier versions.
Just interested to know if my box will have any of the revisions on it.
Finally got around to scanning mine, guess its the detailed ECU info you want:
ECU info obtained with Carista 3.7.5 for Android:
VIN: *****************
CAN network gateway
Part #: 8T0907468T
Coding: 00C303 (hex)
Component: GW-BEM 4CAN-M
[No fault codes]
Ignition authorization
Part #: 8K0907064DP
Coding: 011200 (hex)
Component: BCM2 1.1
[No fault codes]
Central electronics
Part #: 8K0907063P
Coding: 2600D0914134BF311F01000300001D0D4F9DC74A00010141000000 (hex)
Component: BCM1 1.0
[No fault codes]
Body/convenience system
Part #: 8K0907064DP
Coding: 013B042220390C940330020000000000 (hex)
Component: BCM2 1.1
[No fault codes]
Driver's door
Part #: 8K0959793H
Coding: 011C02205021410001 (hex)
Component: TSG FA
[No fault codes]
Front passenger's door
Part #: 8K0959792H
Coding: 011C02205C21410001 (hex)
Component: TSG BF
[No fault codes]
Rear left door
Part #: 8K0959795C
Coding: 010C02204021210001 (hex)
Component: TSG HL
[No fault codes]
Rear right door
Part #: 8K0959795C
Component: TSG HR
[No fault codes]
Heater & air conditioning
Part #: 8T2820043AG
Coding: 66140000 (hex)
Component: KLIMA 3 ZONEN
[No fault codes]
Steering wheel
Part #: 8K0953568G
Coding: 000037 (hex)
Component: Lenks.Modul
[No fault codes]
Back-up camera
Part #: 8T0907441C
Coding: 1023007 (decimal)
Component: J772__Rearview
[No fault codes]
Instrument cluster
Part #: 8K0920980P
Coding: 230F110032002600010400 (hex)
Component: KOMBIINSTR.
[No fault codes]
Parking brake
Part #: 8K0907801H
Coding: [none]
Component: EPB Audi B8
[No fault codes]
ABS
Part #: 8K0907379CA
Coding: 292508 (hex)
Component: ESP8 quattro
[No fault codes]
Steering angle
[ECU not present]
Active steering
Part #: 8K0907144D
Coding: 8C0000 (hex)
Component: DYNAMIKLENK.
[No fault codes]
Parking/steering assist
Part #: 8K0919475J
Coding: 30010D (hex)
Component: PARKHILFE 8K
[No fault codes]
Airbags
Part #: 8K0959655G
Coding: 30363435363030303030554A3052384B3053 (hex)
Component: AirbagVW-AU10
[No fault codes]
Engine
Part #: 8K0907551
Coding: 010C000C240F0128 (hex)
Component: 3.0T SIMOS84
[No fault codes]
Transmission
Part #: 8K0927156H
Coding: 000001 (hex)
[No fault codes]
Headlight aiming
Part #: 8K0907357B
Coding: 5 (decimal)
Component: Dynamische LWR
[No fault codes]
Suspension
Part #: 8K0907364A
Coding: [none]
Component: DAEMPFUNGS-SG
[No fault codes]
Radio
Part #: 4F0035053B
Coding: 010003010000000001 (hex)
Component: Radio U Basic
[No fault codes]
Sound system
Part #: 8T0035223AK
Coding: [none]
Component: DSP Prem
[No fault codes]
Infotainment system
Part #: 8T2035666D
Coding: 010101010206C1EF05000F1E000000010000 (hex)
Component: H-BN-EU
[No fault codes]
Additional functions 2
[ECU not present]
Hi @bobby singh,
I've got a 2013 A5 3.0 TDI and was just wondering which Gen my gearbox was? I'm not sure if you can tell from these details but would appreciate it greatly if you could!
Here are the details:
My Hardware number is: 0B5927156J
Hardware version: H01
Software Number: 8K2927156J
Software Version: 0005
Thanks in advance!
Can you see if this has the latest software rev?
The hardware will be key tbh, the early versions had poor heat protection of the mech unit, hence why they failed so easily as they overheated and even melted elements is what I heard…
