Meyle HD/Lemforder front arm kits?
bhodgkiss
Brackley, Northants
Hi All
Are both pretty good, and where you recommend I buy for a B8 3.0tdi?
I've used lemforder on a passat previously and been impressed.
I'm after a complete front kit with arb drop links and TRE's for the B8 I've just bought
I do like Meyle HD kit having rebuilt my A4 B5 V6 and wife's A2 suspension previously.
Either will do a great job, excellent quality. Fit and forget, hence the reason you don't want to cut corners. Goes without saying to get tracking checked afterwards. The upper arms, assuming the pinch bolt plays ball, then torque when vehicle weight is on the ground so you don't stress the bushes.
Many thanks
ECP with discount is £39 for two front lemforder droplinks - doesn't sound too bad
There's also a lot of geaknob movement over bumps - is that a sign a gearbox mount has failed?
