Are you having problems with it?
If not I would probably leave it alone.
Also what version do you have? Think that screen is for updating maps if iou have Audi connect.
Yes for the MMI firmware as equipment is required to directly connect to Audi's servers, although I believe DJAlix can do this. Don't know why Audi decided to leave that setting in to confuse owners and not put it in a engineers service menu instead...
Firmware for Audi A3 8V MMI systems is updated via SD Card however the VW Group Service tool is needed in order to both initiate and complete the process correctly.
Navigation data is updated as follows:
SD Card Based Navigation Systems (Standard) = Via purchasing and activating a new SD Card
HardDisc Based Navigation Systems (Technology Pack) = over the air via the MMI System update Menu if you have a valid subscription or SD Card via MyAudi.com if you have a valid subscription.
The original posters screenshot is of an MMI Standard system I believe.
