Headlight adjust
V13MKE
Audi A6 3.0TDI V6 Le Mans & Audi TT Mk1 225
Aberdeen, Scotland
Hello,
Believe my headlights are angled too high, have had a few people flashing to suggest full beams are on when they aren't.
Had a brief look in the car setting but there doesn't seem anything to adjust them. Is this a take to the garage job or is it simple enough to do?
If you pop your bonnet, prize out the black plastic trim that fits between the back of the grill you will be able to see one of the fixing points for the headlamps. Loosen the screw then turn the larger disc behind it. Lock the screw back in and try it. If you can park close to a wall or garage door you can mark where your beam hits to compare.
Reactions: V13MKE
There should be two plastic adjusters on each lamp which require an allen key to adjust.
Does your car have xenon or halogen lights?
If you have xenon and haven't done any work on the headlights, your self adjusters may not be working correctly.
Reactions: V13MKE
Okay will have a look, they are xenon. Only work I have done is replacing the sidelights and the DRL's. That was accessing them from the back so don't imagine they will have moved with that.
693
NHN
953
484
