Removing RainEx
Adam14
Cambridge
Hi All,
As per the title I applied RainEx a month or so to my S3, seemed to go on well enough but now we've had some rain I've noticed a few issues which I can only point to the RainEx, these being:
- In the cold weather, my windscreen seems to steam up from the outside, it's not steam it's almost like trapped moisture? But on the outside so have to keep my wipers on until the car heats up
- When raining the wipers come on, but seem to smear? Which actually hinders, didn't do this pre application.
I can only think RainEx is the cause, so is there a way to remove the application so my glass goes back to being product free? And I'll look at applying something else.
Cheers all.
Sent from my SM-G965F using Tapatalk
You'll always get a slight smearing with these aquaphobic solutions especially when the weather starts getting cooler/colder, rain X doesn't last that long so it should start to wear off the more you use your wipers, the symptoms you describe will happen with all windscreen sealants, it doesn't bother me l just wait till the screen heats up a little before l drive off
Reactions: NevMan and Scotty75
Cheers Jassy for the tips! Was just hoping to remove it ASAP, as has been a month and still present. Will hold off on future sealants for now then. Thanks.
Reactions: Jassyo06
I also get this with Angelwax H2Go but never realised it was a side effect of aquaphobic treatment. Learn something new everyday
Sent from my Nokia 8 Sirocco using Tapatalk
Reactions: NevMan
Certainly do! Joys of the forum
Reactions: Scotty75
If you look at a treated windscreen and a untreated windscreen say on a cold morning, you'll notice the treated screen is pale green in tone with some beading/moisture on top of it where as the untreated screen is clear ish, extact same principle applies to paint coated with a product and paint with nothing on it, aquaphobic glass/paint products all hold on to standing water/moisture far more hence the moisture on the windscreen and beading on paint
Reactions: NevMan
Also on a frozen treated windscreen it'll defrost quicker than a untreated windscreen as the ice will slip off easier
Reactions: illingworth22, NevMan and Adam14
now that I do like :icon thumright:
Back to OP, I guess to remove RainX, would need something like their Extreme clean, or another strong APC?
I thought of some alcohol wipes or something, got a degreaser/APC which might do the job? Thanks
FWIW I don't put glass coatings on the driver's side of the screen for the reasons you bumped into. Happy to do the other windows and passenger's side but never been a fan on the driver's side regardless of the coating. Just my opinion, stand down from the flame canons :)
Reactions: Pook, Jassyo06 and Adam14
l hate using window wipers....with a passion,just for safety reason alone a hydrophobic treated windscreen is a god send especially with winter looming....i spend about 30 minutes just cleaning the windscreen and wipers before applying a coating probably more, prep is everything,hence l have never needed to buy a new set of wiper blades on all of my cars
Reactions: scotty76 and NevMan
What do you tend to clean the wipers with? Just wet mf? Any product?
White vinegar and on damp cloth, pulled along the blades does a good job.
Reactions: NevMan
I use glass cleaner mate ie Angelwax Vision strongest glass cleaner out there
lol, fiar enough, thought you may have some special wiper blade concoction :whistle2:
Reactions: Jassyo06
Nah mate if your cleaning glass and then applying a hydrophobic solution i just concentrate solely on the glass because to do it properly it takes time, my glass will get seeing to soon, l have a permanent hydrophobic solution in one of my cardboard boxes lol so going apply this to the glass of the pano-roof
Reactions: NevMan
I use RainRacer, and I'm definitely in the camp of loving the product, although when it starts to wear a little it does smear a bit. The Rain Racer came with a cleaning product, referred to as "burnishing gel". The instructions are adamant that this should be used to clean the window before applying the product, and to be fair whilst I don't actually know what it is, it is an excellent glass cleaner.
I've definitely noticed that if I don't clean the screen properly, or apply the product in a rush, then it doesn't bead as well, noticeable more in fine rain or drizzle. Definitely a better result when taking a good 30 minutes to clean the screen properly first, apply the product, and then buff it off well.
Reactions: NevMan
17
3K
J
732
23
10
