Turbo change
Rob1967
Durham
I am on changing turbo on a6 2.7tdi is there any easy way to get the bottom pipe off I think it's the egr pipe it screwed on from bottom with very little room
Is it possible to cut the pipe as close as possible to the turbo, and would there be enough length to reconnect .
Just a thought.
Sure you not talking about the small oil return pipe? That and the ERG is a pain to remove, and even more so to refit.
It is a small metal pipe directly under turbo bolted to middle of turbo on bottom on opposite side to oil feed pipe witch is on top
If your talking about the small pipe with the green mark shown in this picture then than is the oil return pipe
Mine is different as it doesn't have pipe like that
The one I mean is under turbo held on with 2 torx screw and a oval shape gasket
Sorry don't know then. I would follow the pipe and if it goes down towards the base of the engine then it will be the oil return pipe
It is the silver pipe as this goes on bottom
8K
451
