Hope I can get a diagnoses on this here before I spend money getting a garage to take a look at it. My S3 is a 2011 61 Plate face lift with a CDLA engine noticed a tapping sound so done a video. First part of video is from a cold start and it idling to a low RPM. Second part of video is after a good run getting the engine up to temp. Oil level was at half way. I'm at 45,000 miles now. This is all the history of the car that I know if:
19,651 – 11/04/2016
Haldex Oil Change, Cambelt & Water Pump, Engine Cover, Air-con Flap Motor, NS Front Seals, Rear Washer Jet, Wipers, S3 Badges, High Level Brake Lamp, Oil Top-Up, Minor Service (Oil Filter, Sumplug, Oil), Plates
19,674 – 27/04/2016
MOT
26,024 – 06/09/2016
RH Paddle Mechanism, Coil Springs, Top Mounts
30,732 – 23/12/2016
2 Rear Tyres
32,305 – 16/02/2017
Minor Service (Oil Filter, Sump Plug, Oil), Brake Fluid Due in 7 months
33,377 – 04/04/2017
MOT
41,355 – 11/12/2017
Major Service (Oil Filter, Sump Plug, Spark Plugs, Air Filter, DSG Seal Ring, Oil), DSG Oil Change (Oil & Filter), Brake Fluid Change, 65% Worn Front Brake Pads
43,736 – 03/04/2018
MOT, 2 Front Tyres, Brake Discs at 27.8mm, Recommended Discs and Pads Replaced
If you can also recommend anything I should get changed as preventative measure then please let me know. Cheers
