C7 S6 brake pad options
marriedblonde
Sunny South Coast
Already after 1200 miles I am done with the standard brake pads and he amount of dust they create.
It seems like replacement options are pretty slim. I've found EBC yellow pad (i;ve used reds in the pads and quite like them but never the yellows) or Ferodo DS2500's which I have also used and love.
Anything else out there? EBC's are £166 the ferodos are £238 so not too bad.
Having had the ebc yellow I can say safely don't get these they are noisy and honestly quite useless. My stock pads were better
Sent from my Pixel 2 XL using Tapatalk
Reactions: marriedblonde
EDC Redstuff, low squeal and low dust.
I can highly recommend. I have them on the S7.
Reactions: marriedblonde and Gazwould
Fronts were DP32158C
Rears were DP32082C
EBC Catalogue here
These pads also fit Mercedes (with Brembo calipers) so you may find them listed under Mercedes rather than Audi. Also fit different Audi models (S8)
I got mine from eBay
You can try here just search using the part numbers.
Note that they do not come with wear sensors. I used the original ones.
Also there are anti-vibration pads (stick-on pads). You will need a set of those, however you may be able to reuse the old ones, if you can get them off the old pads without damaging them.
Have a look here Item 12. I ordered the pads through the forum Parts Request service.
4K
