Hi All,
I have a couple of questions about my S3.
I have a black leather Recaro interior and there are wires under the seats connecting them to a loom, would the seats come with the heated elements and wiring and would the connections be behind the air con unit.
The reason I am asking is that I am spending some cash on the car to tidy it up and bits inside like around the headlamp switch and the air con unit are worn.
I also need some guidance with exhaust systems, Ideally turbo back 3 inch system, sports cat? no cat?, how do I get by the lambda sensor error code, bearing in mind that I will be looking for a stage 1 or 2 power increase would a remap cancel the error code?
I am looking for comments on what people have found works for suspension and bigger brake conversions.
I have already had to reattach the door blades as the runners and plastics are corroded and broken, so looking for part numbers or suggestions on how to repair tidily.
Car is showing its age in that there is small amount of bubbling on the Drivers front arch, on the passenger door at the door blade and the car has stone chips on the bumpers/bonnet, should I go for a full respray or just the panels, it is a bright silver. I had a front wing replaced last year and it was a perfect colour match on a 15 year old car.
Any help with this would be great or if you can point me in the direction of threads that I can read and follow up.
I will get some pictures up shortly.
David
David
