A3 8V Low on power.
Tom Shields
Member
Middlesbrough
Hey,
Just driven my A3 back from work and it was really low on power and the EPC light was on the dash. pulled over turned the car off and back on again and all the lights were normal and the power was back.
Scan from VCDS:
Code:
Monday,08,January,2018,18:20:34:07323
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 17.12.0.1 (x64)
Data version: 20171213 DS285.1
www.Ross-Tech.com
VIN: WAUZZZ8V7DA031874   License Plate: T444TDS
Mileage: 72567km-45091mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V7DA031874   Mileage: 72567km-45091miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CMBA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 J    HW: 04E 907 309 A
   Component: 1.4l R4 TSI   H08 6034
   Revision: WAH08---
   Coding: 02190032232401082000
   Shop #: WSC 17339 003 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016J 002012
   ROD: EV_ECM14TFS01104E906016DE_AU37.rod
   VCID: 295FB8E448E5B962B8C-807C
1 Fault Found:
19404 - Turbo/Super Charger Boost System
          P2263 00 [032] - Performance
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 72553 km
                    Date: 2018.01.08
                    Time: 17:38:21
                    Engine speed: 1180.50 /min
                    Normed load value: 16.5 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 4 °C
                    Intake air temperature: 5 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 11.402 V
                    Unlearning counter according OBD: 40
                    Charge pressure actuator: specified position: 140.00 %
                    Bypass valve f high press turboch turbine inlet: actual value: 102.78 %
                    Charge pressure actuator: adaptation for lower stop: 4409.0 mV
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 0
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 55
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 66
                    Bypass valve for high press turboch turbine inlet: uncond volt: 4500.4 mV
                    Charge air pressure: actual value: 1010.94 hPa
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 10F18AA220232A6D017F060701C7290851045480608094F20239000805
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008.rod
   VCID: 7DF7BCB4ECEDF5C2A44-8028
No fault code found.
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-043.clb
   Part No SW: 8V0 820 043     HW: 8V0 820 043
   Component: AC Automat    H11 0031
   Revision: 20019000    Serial number: 00000000035015
   Coding: 00100004000000011000000000001100
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   ROD: EV_AirCondiFrontVaAU37X.rod
   VCID: 6FEB96FCB6819752268-803A
   Relative humidity sensor in fresh air intake duct:
   Subsystem 1 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: FC698B86000000000001
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011302601776
   Coding: 07000842C20100DD03044000B31407A80000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 43830A4CCA894332920-8016
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 121208  041 0580
   Serial number:         130112203253
   Coding: 0A47F7
   Light switch:
   Subsystem 2 - Part No SW: 8V0 941 531 N    HW: 8V0 941 531 N
   Component: E1 - LDS MQB  H05 0032
   Serial number: 25 08 2012  00000854
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY12348027P
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000055787589
   Relative Air Humidity Interior Sender:
   Subsystem 5 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20259642
2 Faults Found:
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [009] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 192
                    Mileage: 72351 km
                    Date: 2018.01.04
                    Time: 16:50:16
267030 - Siren / Alarm Horn for Anti-Theft Alarm System
          U1137 00 [008] - Implausible Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  009 0026
   Revision: --------    Serial number: 60831302419409
   Coding: 0000050001
   ASAM Dataset: EV_EPHVA14AU3700000 002015
   ROD: EV_EPHVA14AU3700000_002_VW27.rod
   VCID: 377B6E9C8E511F923E8-8062
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
   Component: AirbagVW20    009 0349
   Serial number: 003GER00PC7I
   Coding: 98CCC0000C0000005C5400CA00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 499F1864E8A5996258C-801C
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 002 201 13
   Component: SideSensor_Df  001 0887
   Serial number: 35767000000CEA6D4C0D
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 002 201 13
   Component: SideSensor_Pf  001 0887
   Serial number: 35867000000FD7BC6C0J
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 400 801 13
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502AF0D5D651B32K
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 400 801 13
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502AF0D5D65591BU
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 211 12
   Component: FrontSensor_D  001 6149
   Serial number: 3556502B50CC5BF4B23V
   Coding: 2D2D2D
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 501 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 22865029F0D36242D38H
   Coding: 2D2D2D
   Pedestrian Protection Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 501 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 22965029F0D3624343BD
   Coding: 2D2D2D
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 501 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 23065029D0D3624402F3
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 24011308491408
   Coding: A408
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_011_AU37.rod
   VCID: 77FBAE9CCED1DF92FE8-8022
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 8V0 920 970     HW: 8V0 920 970
   Component: KOMBI         H24 0570
   Coding: 27AD0100228046000100EA00000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
   VCID: 79FFA8A4F8C5C9E288C-802C
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 H    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1126
   Revision: --------    Serial number: 0000309008
   Coding: 030100F42B0864005B000248080B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 008010
   ROD: EV_GatewLear_008.rod
   VCID: 36656398895BE69A25E-8062
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Component: E221 - MFL  H02 0014
   Serial number: 19 01 2013  C0181070
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000002990920815
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 09011300010959
   Coding: 00100E204001040100001002
   ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 3D777CB4AC6D35C2E44-8068
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 81
   ASAM Dataset: EV_SteerAssisMQB 008022
   ROD: EV_SteerAssisMQB_008.rod
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 19011300090186
   Coding: 001006204C01040100001002
   ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 3C7171B0B7773CCAD3A-8068
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 8V0 035 874 A    HW: 8V0 035 874
   Component: MU-S-ND-ER    039 0370
   Serial number: A7F01201131055
   Coding: 01730001FF00000021111101000A00032F0004460100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3A7D77A8BD4302FAC16-806E
   Data medium:
   Subsystem 1 - Part No SW: 8V0 919 866 A    HW: -----------
   Component:  ECE 2013  --- 0021
   Serial number: --------------------
   Display unit 1 for multimedia system:
   Subsystem 2 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H47 0013
   Serial number: AUZ8Z9CG200EJ8
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000019111200010109
1 Fault Found:
6179 - Display Module 1 for Multimedia System
          U905156 F6 [008] - Cable for Video Signal; Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 72351 km
                    Date: 2018.01.04
                    Time: 21:34:55
                    Voltage terminal 30: 12.1 V
End-------------------------(Elapsed Time: 03:28)--------------------------
Any ideas would be really helpful.
Coolant temp was 4 degrees when error recorded so looks like it was just after you started the car. Is the battery OK , did it start straight away. Could just be one of those things it may not do this again. You could do a quick check for boost leaks, check all the boost pipes for signs of leakage, look for wet oil patches.
Started first time. It's been an intermittent fault. Had the light come on twice before but not noticed the loss in power.
