Agree with Raz, the overall refinement is pretty exceptional.Refinement and the led strip on the bottom of the door speakers.
The fact that it’s faster than it looks
@Inked, I have to agree with you. I’ve lost count at the number of times some boy racer has pulled beside me, looked across and thought, it’s only A4. The look of astonishment on their faces as I serenely pull away from them is a picture.The fact that it’s faster than it looks
MMI App....?I like,,,,,,,,, heated seats, refinement, clocks, the way the dash vents light up, illuminated door sills, MMI App (especially the daughters face when I lock the car with it), LED lights,,,,,,,,, oh sod it. I LIKE IT AL !!!!!!
Its the MMI connect app. Lets you connect to your MMI from your mobile. Lets you unlock and lock the doors, check fuel levels, mileage, the alarm, if the doors, windows, boot, lights etc is open or on. Were the car is located, warnings status, along with the been able to play your music streamed to your mobile.MMI App....?
Not to derail, but does the app allow you to turn the car heating on?
I do like the idea of it warming up while I'm necking a wakeup coffee!
It’s not going to heat up if the engines not running.
Yes in extreme cold climates like Canada etc. Webasto make them and they run off kerosene, they can be fitted to any car.
It would improve mpg when you use it as you are not starting off with a cold engine, it would be near operating temp.
Got to be happy with that as I expect that will improve too as the engine is run inAlso impressed with MPG, just calculated the fuel/MPG the old fashioned way (maths) and my 190ps diesel has returned 53mpg, only 550miles in.
I am mate, a bit more frugal than your beast BUT mine is a bit less fun than yours.Got to be happy with that as I expect that will improve too as the engine is run in
