Xenon bulb replacement
TheShire
anyone have any good links for replacement Xenon bulbs (d3s) on my 2014 A4 (I'm waiting for Trups to get back to me) I'm not sure if they have to be bi xenon bulbs or not
Bixenon is the headlight type, not the bulb.
Its 1 bulb 1 beam but a motor in the headlight adjust the beam to suit.
Trups will get back to you soon, he's a good lad.
Hth.
Reactions: martinivw
Thanks Nigel, wasn't sure on the bulb , tbh just looking for a quick replacement until I can aford Trups amazing d3s to D1s kit
Soo tempted by the conversion kit Trups does.
Question...do the D3S bulbs loose a bit of their brightness over time? Cant say I can see my lights being as 'bright' as they were a year ago.
I got my bulbs from Halfords. £90 each unless you have a trade card then they are £45.
Not sure tbh, however mine are not as good as I would have expected, that's why I will buy the D1 kit, in time
How easy is it to swap the bulbs out?
Looks easy enough, plastic cover between the 2 headlights, then 4 torx screws on each light, disconnect the loom plug and pull the whole headlamp out, disconnect the bulb and change over, (I had a look at a YouTube video)
I'm learning something new here, I always assumed that HIDs were just HIDs, but now I see Xtreme Vision and Night Breaker versions are available too, hum, will I won't I - ?
One of mine went, I wasn’t sure if it was a bulb or the ballast I swapped bulbs, turned out to be a bulb. Went to TPS bought a pair replaced both.
10
864
50k
9
9K
