Lucas/ATE rear brakes
Andreas DB
Are there any differences between Lucas and ATE rear calipers?
I have ATE front calipers, and I need new rear brakes, but the only ones I can find is for the Lucas system. They seem to look identical and use the same size discs.
I have ATE on the front of my Audi and TRW/Lucas on the rear. They are different (not just in size) and I suspect VAG mix & match like this on other models. There should be a sticker on the boot floor and service book giving 3 letter codes which denote the front and rear brake fittings for your car so that you can purchase the correct discs/pads.
I could not find any stickers, I know it should say on the brake reservoir, but after 22 years it's unreadable.
I am going to take a gamble hoping that there is no difference, and just order them.
All B5 rears are the lucas type calipers.
If its a FWD theres an earlier steel version and a later alloy version.
quattros all got the steel version with the exception of facelift S4's, which got a different alloy caliper, but still lucas.
Reactions: Andreas DB
10
14K
839
740
