Hi folks, im looking for some advice on diagnosing my latest issue with my A4 2.0tdi BLB.
Recently my clutch has been sounding awfully noisy, suspected release bearing type noise !
As usual, life has got in the way of even looking at this ......until now, as i have problems engaging 1st gear.
Going through all the gears with engine running at idle, all 6 gears are not smooth to engage.
When 1st gear wont engage, its not a grinding noise but just a solid resistance on the gear stick.
The car has done over 140K and just want to know how to determine if the clutch is gone or if something else may cause these symptoms....ie, rivet pin on gear selector rod in gearbox (i read somewhere that these can and do shear causing 1st and 2nd gear issues ) however i may be wrong.
IF the clutch is the culprit, is it worth replacing the flywheel at the same time. ?
Any advice on what to check before I buy the clutch kit would be appreciated.
thanks in advance
Barry
thanks in advance
Barry
