Dis washer bottle help
Jamie1087
Swansea
I know there are loads of threads on here about the dis retrofit but could someone show me which wire come out of PIN 1 from the blue connector
There's no wire on pine 1.
You have to add a wire to pin 1 all the way to the washer bottle..
Sent from my SM-G935F using Tapatalk
or just ground it to stop the waring
I am looking to forums it, but I've read that there is already a wire in pin one, just wanted to know which pin was pin one as I haven't looked to see if it's printed on the blue connection and cannot find the wiring diagram for it either
Hi not sure what ur looking for this is the pin
Sent from my SM-A300FU using Tapatalk
None..
Pin 1 is empty and you'll need to add a wire there..
The other end doesn't need splicing.
The other. End need to be connected to a metal contact point to prevent the warning to show on the cluster.
D
D
402
Deleted member 85022
D
