Hi guys,
I have a 2005 A3 with the BKD engine. My EGR still works (got no error light), however the EGR appears to be leaking oil from the vacuum side of the EGR assembly and oil is coating the areas behind the EGR/on the engine block and inlet manifold. This looks to me as a possible hole in the diaphragm and the turbocharged air/EGR gases are being forced out through the round metal shell protecting the diaphragm. I've heard that the diaphragm can develop holes and this is why the leak develops. It mustn't be too bad a hole, as the EGR is still working? Can anyone confirm if this theory stands?
I did a little tissue test by revving the engine, placing a tissue behind that metal shell and seeing if the tissue moves (because of an air leak). The tissue certainly did appear to shake and my mate also confirmed it.
So far these are the options I have:
1) Fit new EGR valve (£65-70)
2) Solely blank the EGR valve although I don't think this will solve the problem. There will still be turbocharged air and possibly oil leaking through that diaphragm, just hopefully not as much soot. (£4-£5 for blanking plate.)
I could do a combination of option 1 and 2 and this would therefore cost £70-£75.
3) Fit an Allard delete pipe (no chance of leakage and no exhaust gases coking my manifold up). I understand that the EML light will come on but I'm aware that it can be mapped out. (£53 for Allard kit + small mapping fee, below £50)
What shall I do people? I'm leaning towards option 3.
