Cutting out issue... After K04-064 conversation
rich4130
Thoughts on this?
I have carried out a K04-064 TFSI Turbo conversation on my 1.8t LCR..all running well aside from one fault... it cuts out and stalls under heavy braking?!
I cannot find and boost vac/leaks, but it does not do it with the MAF unplugged (the MAF is good!) which would be a sign of a leak but I have checked all joints and eliminated these (I think!)
With the brake servo disconnected it does not do it, it has a new check valve fitted...but the servo holds a vacuum?!
TB cleaned, and realigned with VCDS, PCV system disconnected for elimination!?
I am awaiting mapping so the N75 is unplugged, has revo software on currently..
Has a Bosch 044 fitted with Bills adapters, standard injectors for now..
Has a new check valve and seal on the servo where this attaches... the servo still had vacuum after being left for the weekend when I swapped this over so fairly confident that is ok... it held a vacuum til the pedal was pressed with a tester.
Really struggling!?
It has the DV Relocated and obviously custom intake pipes, I have bypassed the evap cannister, blanked off the port on the TB.
Wellcooler, custom boost pipes with a silencer bypass on the turbo
It does not do it until the car is up to operational temp, and starts on the button after it has stalled.
Fuel trims are -3 approx.. is clearly running mega rich but would be with no n75..
Lcr
by rich4130 on Audi-Sport.net
Any help appreciated!
Rich
I'll grab a log and post it up...thanks for the reply.
8270
Sorry for the photo.. laptop died..
However I think the 1.991 in column c may be the issue..?
anything above 1 in this is running lean? so looks like a massive air leak under braking... or a boost hose leak when the engine is rocking as the car brakes
1.991 is the normal value on over run as the ECU switches the injectors off...
Ahh.. not that then!
I better do some more comprehensive logs and post them up.
Thanks for the reply
