Car turns over but won't start.
mrmen
Hi, I have Audi A3 2.0 TDI 2005 that suddenly just won't start up, it turns over fine but just doesn't fire up.
I thought that maybe it wasn't getting fuel so I took the screw out the fuel filter and turned the key and fuel pumped out the top so I think the fuel side of things is ok.
The glow plugs were all replaced last year as I had a problem with one of them, there is still this fault code 17058 which relates to the glow plug circuit but it has had this code for over a year and has always started up so I don't think this is stopping it from starting but there're no new fault codes to go.
Anything else that you guys think I should check before I have to send it off to the garage?
Thanks.
The timing belt looks good, I'm starting to think it might be the crankshaft sensor but don't know how to check that so might just replace it and hope for the best.
Check cranking speed with vcds mate
12
9
22
S.
654
